Solution of Integral \frac{1}{lnx}
  • Thread starter Thread starter rock.freak667
    Integral
The discussion revolves around the integral of the function \(\frac{1}{\ln x}\). Participants are exploring different approaches to find a solution or a closed form for this integral.
  • One participant attempts a substitution with \(t = \ln x\) and transforms the integral into a series representation. Others question the existence of a simpler closed form solution and reference the logarithmic integral function. There is also mention of the exponential integral and its relation to the problem.
Participants are actively discussing various methods and representations of the integral. Some express uncertainty about the integral's complexity and the appropriateness of using series approximations. There is no explicit consensus on a solution, but several lines of reasoning are being explored.
Some participants note that familiarity with certain integrals, such as the exponential integral, may be necessary to fully engage with the problem. The discussion reflects a mix of knowledge levels regarding advanced mathematical concepts.
rock.freak667
Find
[tex]\int \frac{1}{lnx} dx[/tex]
Let [itex]t=lnx \Rightarrow \frac{dt}{dx}=\frac{1}{x} \Rightarrow dx=e^t dt[/itex]
[tex]\int \frac{1}{lnx} dx \equiv \int \frac{e^t}{t} dt[/tex]
and well
[tex]e^t= \sum _{n=o} ^{\infty} \frac{t^n}{n!}[/tex]
[tex]\frac{e^t}{t}=\sum _{n=o} ^{\infty} \frac{t^{n-1}}{n!}[/tex]
[tex]\int \frac{e^t}{t}=\int \sum _{n=o} ^{\infty} \frac{t^{n-1}}{n!}[/tex]
[tex]=\sum _{n=o} ^{\infty} \frac{t^{n}}{(n+1)!}[/tex]
Is there any easier closed form solution for this?
That would be, I guess, the http://mathworld.wolfram.com/LogarithmicIntegral.html" .
Apparently it's.
[tex]Ei\:(1,-1\ln(x))[/tex]
This seems a little unfair though unless you knew about such an integral?
Schrödinger's Dog said:
Apparently it's.
Nope,never even heard of it. But my usual way is, if you can't get it out directly, make a series and approximate and hopefully it might turn into something nicer.
Probably but with the exponential integral and imaginary numbers there it will only be equivalent to the actual integral in a series. Although I think in that case they are asking you to show the series rather than the actual integral as it is in distinct maths language. Like to see how to do this, sorry but I have no idea, so can't help, I just thought the answer my maths program spat out was quite interesting, good luck.
At least you know that the answer involves an exponentiation, and imaginary numbers I suppose.
erm … [tex]=\sum _{n=o} ^{\infty} \frac{t^{n}}{n.n!}\,.[/tex] :smile:
Ah silly me...forgot that n-1+1 is n and not n+1..thanks
  • · Replies 16 ·
  • · Replies 105 ·
13K
