Sketch the region R=T(S) in xy-space
  • Thread starter Thread starter stvnseagal
    Sketch
The discussion revolves around the transformation of a rectangle defined in polar coordinates into its corresponding region in Cartesian coordinates. The original poster is tasked with sketching the region R=T(S) where S is defined as a rectangle in the r-θ space.
  • Participants explore the nature of the rectangle in polar coordinates and its transformation into Cartesian coordinates, questioning how a rectangle can appear as a quarter circle in the xy-space. There are discussions about the implications of the transformation T and the definitions of geometric shapes in different coordinate systems.
Participants are actively engaging with the definitions and implications of the transformation. Some have provided insights into the confusion surrounding the terminology of "rectangle" in the context of polar coordinates versus Cartesian coordinates. There is a recognition of the complexity involved in visualizing the transformation.
There is an ongoing discussion about the characteristics of the rectangle in r-θ space and how it translates into the xy-space, particularly noting that certain vertices map to the same point in Cartesian coordinates. The term "rectangle" is being scrutinized based on its geometric properties.
stvnseagal
Consider the rectangle S=[0,1]x[0,[tex]\pi[/tex]/2]
Sketch the region R=T(S) in xy-space.
T(r,[tex]\theta[/tex]) = (rcos[tex]\theta[/tex],rsin[tex]\theta[/tex])
how is the given a rectangle in polar coordinates? it seems to me to be a quarter circle
S is a 'rectangle' in cartesian [r,theta] space. The image of T in cartesian [x,y] space is, indeed, a quarter circle. If you regard T as a transformation between polar r-theta coordinates and cartesian x-y coordinates then it is really a quarter circle in both. I'll admit the difference is a bit confusing if you are used to thinking of r,theta as polar coordinates. If it helps try thinking of T(x,y)=(x*cos(y),x*sin(y)) both in cartesian coordinates. That really does take a rectangle into a quarter circle.
Welcome to PF!
Hi stvnseagal! Welcome to PF! :smile:
I think the question is just trying to confuse you …
Technically, "rectangle" means all its angles are right-angles - which they are! :smile:
It's just that there's only three of them!
:smile: Don't worry! :smile:
It is a rectangle in "r, [itex]\theta[/itex]" space, not in x,y space. Since the two vertices (0, 0) and (0, [itex]\pi/2[/itex]) both have r= 0, T transforms both of them into the single point (0,0) in x,y space. (1, 0) in r, [itex]\theta[/itex] space is transformed into (1, 0) in xy space and (0, 1) in r, [itex]\theta[/itex] space is transformed into (0, 1) in xy space.
Tiny Tim, "technically" a rectangle has four vertices! As I said, the "rectangle" part on applies to r, [itex]\theta[/itex] space.
