Solve Partial Fractions: Step-by-Step Guide
The discussion revolves around solving a partial fraction decomposition for the integral of the function \(\frac{1}{x^2 - 1}\). Participants are exploring the steps involved in breaking down the expression into simpler fractions.
  • Participants discuss setting up the equation for partial fractions and question how to derive the coefficients A and B. There are varying suggestions on whether to substitute specific values for x or to equate coefficients directly.
The conversation includes multiple perspectives on how to solve for the coefficients in the partial fraction setup. Some participants suggest substituting values for x, while others advocate for equating coefficients directly, indicating a productive exploration of different methods.
There is some confusion regarding the proper approach to finding the coefficients, with participants debating the merits of substitution versus direct coefficient comparison. The original poster's notation and setup are also questioned for clarity.
LadiesMan
[SOLVED] Partial Fractions
1. Evaluate:
[tex]\int \frac{dx}{x^{2} -1}[/tex]
Attempt:
[tex]= \int \frac{dx}{(x+1)(x-1)}[/tex]
[tex]= \frac{A}{(x+1)} + \frac{B}{(x-1)}[/tex]
[tex]= \frac{Ax - A + Bx + B}{(x+1)(x-1)}[/tex]
Where do I got from here? Thanks
Hi LadiesMan! :smile:
(erm … what happened to the integral sign, and dx … ?)
Easy! You just solve Ax - A + Bx + B = 1.
So A = … , B = … ? :smile:
so A = Ax + Bx + B -1
and B = -Ax + A - Bx -1??
Ax-A+Bx+B=1 for all values of x
meaning for any value of x you put in there, it will always be equal to 1
Choose some suitable values for x to get A and B
You could do A(x-1) + B(x+1) = 1
Then to get rid of the A, substitute x = 1 and find B.
To get rid of the B, substitute x = -1 and find A.
That means:
(1/2)ln(x-1) - (1/2)ln(x+1) + C
Therefore Since: (1/2)ln(x-1) = ln(x-1)^1/2 and (1/2)ln(x +1)= (1/2)ln(x +1)^1/2
ln(x-1)^1/2 - (1/2)ln(x +1)^1/2 + C
Natural log rule ln a - ln b = ln (a/b)
Thank you =)
… never substitute …
No! :frown:
It's a polynomial, and you just put all the coefficients equal to 0.
It's (A+B)x + (B-A-1) = 0,
so both the brackets must be 0. :smile:
Never substitute - it makes it look as if you don't understand what a polynomial is!
(I agree that, technically, that's the same as substituting x = 0 and ∞; but that requires an extra line, and it doesn't work if you have x^2 or higher.)
Tiny Tim, since that equation is true for all x, you certainly could get substitute any two values of x to get 2 equations to solve for a and b. Of course, it is true that if a polynomial is 0 for all x, then its coefficients must all be 0- that's typically simpler than substituting specific values for x.
Ladies Man, a somewhat simpler method for partial fraction is this:
You want to find A, B such that
[tex]\frac{A}{x+1}+ \frac{B}{x-1}= \frac{1}{x^2- 1}[/tex]
Multiply both sides by x2-1 to eliminate the denominators:
[tex]A(x-1)+ B(x+ 1)= 1[/itex]<br /> Now substitute x= 1 and x= -1 to find A and B.[/tex]
Thanks everyone! =P
  • · Replies 105 ·
13K
  • · Replies 18 ·
