How can I calculate the electric field and force between two charged rods?
The discussion revolves around calculating the electric field and force between two identical charged rods positioned on the horizontal X-axis. Each rod has a uniform charge distribution and a specified length, with a defined distance between their centers.
  • Participants discuss the need to integrate along the length of the rods to find the force exerted by one rod on the other. There are questions about the setup and the integration process, with some participants seeking clarification on specific terms and concepts.
Some participants have provided guidance on how to approach the integration and the application of relevant equations. There is an ongoing exploration of the integration process, with one participant expressing appreciation for the assistance received. However, there is no explicit consensus on the final answer, as further confirmation is requested.
Participants have noted potential language barriers affecting comprehension, and there are references to specific equations and variables that may require further clarification.
Nasserz
[SOLVED] Electric field and force ...
We have 2 identical thin rods , each has a length of 2a and carry a charge of +Q , uniformly distributed along their lengths , and both lie on the horizontal X-axis , and the distance between their centers is "b" ...
I need to calculate the electric field and the magnitude of the force exerted by the left rod on the right one.
I know that F=Q*E
and the electric field done by a charged rod on a point in its axis is E= K*Q/d(d+L) where L is the length of the rod , and d is the distance between the rod and the point.
Well I didn't know how to start :S , no need for a full solution , I just need a push and tell me how to start to solve it .. thanks.
You have to integrate along the length of the right rod.
If [itex]\lambda[/itex] is the linear charge density of the right rod, then find the force due to left rod on an element of length dx on the right rod which is at a distance of x from the left rod. Now integrate, putting the proper limits of x, that is, the values of x on the left and right extremities of the rod on the right respectively.
can someone explain a litle bit more .. didn't really understand ... my english isn't that good
Nasserz said:
I know that F=Q*E
So you don’t need a push, but a slightly bigger shove. Here goes!
Draw a diagram first of the two rods. Take a small length dx on the right rod, at a distance x from the right tip of the left rod. This dx length has got a charge of dq = [itex] \lambda[/itex]dx.
What is the field at this point due to the charge of the left rod? This is at a distance of x from the right end of the left rod. Apply the formula you have written. (I have not checked it, but looks all right.) The field should be then KQ/[x(x+2a)].
So the force on this dq on the right rod should be given by:
dF = Field*Charge = KQdq/[x(x+a)] = K[itex]\lambda[/itex]dx/[x(x+a)] => the total force F should be given by:
[tex]F = \int^{b}_{b-2a}\frac{KQ\lambda dx}{x(x+2a)}[/tex].
thanks mate , that's very helpful ... :)
I continued the integration .. and I got as final answer : F = (KQ^2/4a^2)ln(b^2/b^2 - 4a^2)
I think it is right , can you confirm this ?
thanks a lot mate , I really appreciate your help ^_^ , you are the best.
Bracket is missing: (KQ^2/4a^2)ln(b^2/(b^2 - 4a^2)).
  • · Replies 18 ·
