Screen capture of Windows Media Player
by pmb_phy
Tags: capture, media, player, screen, windows
pmb_phy
pmb_phy is offline
#1
Mar28-08, 03:03 PM
P: 2,955
I have a mpeg video which I can play using Windows Media Player. I tried to do a screen capture using Paint Shop Pro. However the screen capture was unable to capture the image of the video on my screen. How can I get a video image into a jpeg file?
Pete
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
Zenparticle
Zenparticle is offline
#2
Mar29-08, 11:13 PM
P: 47
Try using windows movie maker. It will allow snapshots of your video . Also Animation shop would break up the movie into frames, then just save the individual frame as a jpeg.
mgb_phys
mgb_phys is offline
#3
Mar30-08, 12:19 AM
Sci Advisor
HW Helper
P: 8,961
Media player uses diectX to draw directly to the video bypassing windows - so most screen capture won't work it just 'sees' the reserved area that directX is drawing into.
You could use something like VLC ( a free media player) to save a single frame or search for a screen capture that can do directX
robphy
robphy is offline
#4
Mar30-08, 12:08 PM
Sci Advisor
HW Helper
PF Gold
robphy's Avatar
P: 4,108
As suggested, Windows Movie Maker is the simplest solution with what you already have [in Accessories...].
An alternative to using VLC, I prefer "Media Player Classic"... which can also save frames to a file. (Media Player Classic is my main video player... instead of using WMP.)
[command-line] MPlayer can extract frames from video into a file... which can be used in a script.
For something fancier than a media player...
try Virtualdub [which can import MPEG]... which can copy a frame to the clipboard.
For general screen-captures, including these video layers, try SnagIt.
I wonder if its possible for Paint Shop Pro to do the capture
by setting your video-card hardware-acceleration (in Display Properties->Settings->Advanced->Troubleshoot) to "None"...
possibly turning off DirectX features.
pmb_phy
pmb_phy is offline
#5
Mar30-08, 11:52 PM
P: 2,955
Thanks everyone. I was able to capture the photos I wanted and was able to construct the web page I wanted to create.
The video is from Bob Lazar's web site. Its at
http://www.boblazar.com/closed/downl...DISCFLIGHT.MPG
On the web page I just created I show that the video is a fraud. Its not as if it was hard to do either. Lazar claims to be a physicist who worked at Area 51 where the tested alien flying discs. He claims he was involved in the back engineering of the flying disk (although all he has for proof is a W2 form which shows he recieved $900 from US Naval inteligence in 1987). The video is quite reminisent of a commutor generated animation. The obvious fault, which Lazar either missed or didn't figure out, was that the light rays which are casting a shadow of the disk on the desert floor cannot have come from the Sun but had to come from a nearby point source! Its really obvious so you don't need the diagrams I created nor the web page either. Take a look and see what a poor job this so-called physicist did.
Best wishes
Pete
remilt
remilt is offline
#6
Apr9-10, 10:57 AM
P: 1
I prefer use the program Screen VidShot, it very helps me in work.
mathman
mathman is offline
#7
Jun27-11, 03:41 PM
Sci Advisor
P: 5,935
Avidemux is a utility which has movie maker capability and also an option to save images as jpeg. It is available through snapfiles.
Register to reply
Related Discussions
Screen Capture Need Computing & Technology 12
problem with windows media player 11 (plz help) Computing & Technology 3
Having A problem with windows media player 11 and a DVD. Computers 3
Media Player & Quicktime *grumble* Computing & Technology 2
What is your favorite Media Player Computing & Technology 2
