Special Relativity, accelerating frames, proper time
The problem involves a particle undergoing constant acceleration in a laboratory frame, transitioning from rest to a speed of 0.5c over a duration of 2 seconds. The main objective is to determine the proper time experienced by the particle during this acceleration.
  • The original poster attempts to integrate the proper time over the interval of acceleration but expresses confusion regarding the integration process. Some participants suggest using the relationship between proper time and the laboratory frame time, while others offer to check the calculations provided by the original poster.
The discussion is ongoing, with participants providing hints and clarifications. The original poster has shared their mathematical approach and is seeking feedback on its accuracy. There is an exploration of the definition of "proper time," indicating a conceptual inquiry into its meaning.
The original poster notes difficulty with integrating limits in their mathematical expressions and mentions that the term "proper time" is not defined in their textbook, suggesting a potential gap in foundational understanding.
iamaelephant
A particle has a constant acceleration in a laboratory from 0 to 0.5c in 2 seconds. What time elapses for the particle (i.e. what is the proper time for the particle)?
Hint You will have to integrate the proper time of the particle over the two seconds as measured in the laboratory frame. You may need to look up an integral such as [tex]\int\sqrt{a^2 - x^2} dx[/tex]
You tell me
I'm pretty sure this isn't a difficult problem, I think I may be going about it the wrong way.
I figure I need to integrate dt' over the interval of acceleration, but I'm confused about how I go about this. Any help would be greatly appreciated.
It's constant acceleration in the lab frame. That means v=a*t. dt'=dt*sqrt(1-v^2/c^2). You are right, this shouldn't be at least that hard to start. Please start and tell us where you are confused.
Hi Dick, sorry for the late reply, busy weekend. Thanks for your help, I think I got it but I'd appreciate if you (or someone) could check to see if I did things right.
[tex]dt' = \frac{dt}{\sqrt{1 - \frac{v^2}{c^2}}} = \frac{dt}{\sqrt{1-\frac{(at)^2}{c^2}}}[/tex]
[tex]= \frac{dt}{\sqrt{1 - t^2(\frac{a}{c})^2}}[/tex]
[tex]= \frac{(\frac{c}{a})^2}{\sqrt{(\frac{c}{a})^2 - t^2}} dt[/tex]
Therefore
[tex]t' = \frac{c}{a} \int \frac{dt}{\sqrt{(\frac{c}{a})^2 - t^2}}[/tex]
[tex]= \frac{c}{a} \arcsin{\frac{t^2}{(\frac{c}{a})^2}[/tex]
[tex]= 4 \arcsin{\frac{2}{16}}[/tex]
[tex]= 0.501 seconds[/tex]
I'm not sure how to put limits of integration into Latex but it's implied throughout to be t=0 and t=2s
The answer seems reasonable but I'd appreciate if someone could quickly go over my maths to see if I bungled it. Thanks! :D
Also just so I'm clear, does "proper time" mean the amount of time that has passed in the frame of some object, regardless of whether it is accelerating or not? The words don't even appear in my textbook unfortunately.
  • · Replies 21 ·
