Thread Closed
beta particles
Share Thread
Apr3-08, 06:51 AM   #35
Admin
beta particles
Quote by Physicsissuef View Post
M_1 and M_2 are just points like S_1 and S_2. They don't refer mass, and also W is refering the kinetic energy of the electrons. So I probably think the kinetic energy of the electrons is discontinius because of the different "speed of ejection". Is this correct?
Ah, my apologies, I was thinking of mass, rather than one's OP.
The population distribution is continuous, more or less. It is based on the measurement of a large population in which each decay is a discrete event with a unique beta energy. Taken together, with some large N, e.g. 1020 (arbitrary example), one observes that population distribution when one plots the number of particles of energy between E and some ∆E. When ∆E gets very small the distribution looks like a continuum.
Each radionulide has a unique distribution, with a unique mean and max value, but the shapes are much the same, because although the energies are different, the same weak process applies.
Apr3-08, 07:22 AM   #36
Quote by Astronuc View Post
Thank you very much. I suppose you made excellent posts, but, (maybe it is because of the translation or the difficulty, more of the things I can't understand. Can you explain with simpler words, and maybe give me some simple analogy to understand what you mean?
Apr4-08, 04:53 AM   #37
Why then there are only two dots (M_1 and M_2). If there is unique distribution for every radionuclide, then there will be infinite numbers of distributions, or not?
Apr7-08, 02:59 PM   #38
Astronuc, please answer me, my last question...
Apr7-08, 03:17 PM   #39
Recognitions:
Homework Helper Homework Help
Physicsissuef: you can find the forumulas (and how to derive them) for the beta-probablity distribution in Kranes nuclear textbook - Introductory Nuclear Physics.
Apr7-08, 06:19 PM   #40
Beta- emission, may vary from a radionuclide to another but in general the energy distribution graph looks like the same for every radionuclide, apart for the maximum energy.
The spectrum of the Beta emission is continuos due to the random ripartition of momentum and energy betwen neutrino.
Energy distribution for B-emission of P32
Apr8-08, 01:49 AM   #41
So there are only 2 kinetic energies for every nuclei?
Apr8-08, 04:30 AM   #42
Recognitions:
NO! There exists an energy distribution, which is quite similar for each nucleus. You nay want to look for the derivation of this distribution shape, see for instance the reference i gave you.
Apr8-08, 05:14 AM   #43
Why there are 2 points M_1 and M_2 is my question??
Apr8-08, 05:27 AM   #44
Recognitions:
And as I said, if you want to find out why this probability distribution arises check the reference I gave you..
Perhaps you should google 'probability distribution' to learn more about this concept.
Apr8-08, 05:36 AM   #45
Admin
Because the function is always positive and it increases from zero to some maximum and then decreases to zero again, so that for each ordinate value, there are two corresponding values on of the abscissa. Note that there is one maximum value.
Draw an inverted parabola, and one would see that for each y there are two values of x, except for the maximum value of which there is one.
There is a continuum of energies (between 0 and Emax), and Emax is an upper limit.
Apr8-08, 05:51 AM   #46
I mean, how is possible for one value of beta particles, to have 2 values for the kinetic energy of the electrons?
Apr8-08, 05:55 AM   #47
Recognitions:
now you are just writng things I cant understand.. check your english.
on your y-axis you have the NUMBER of electrons emitted. On the x-axis you have their energy. Please check 'probability distribution function' on google, I think you need this.
Every beta particle has just ONE value of Energy, but what energy - and the fraction of the beta particles who has a perticular energy- is given by the distribution function.
Apr8-08, 06:10 AM   #48
On the x-axis I have number of beta particles, and on the y-axis I have the kinetic energy of electrons...
Apr8-08, 06:17 AM   #49
Admin
On the very first image posted, the vertical (y) axis (ordinate, dependent variable) is number of particles and the horizontal (x) axis (abscissa, or independent variable) is the energy.
By convention, in Cartesian coordinates y-axis is vertical and x-axis is horizontal when looking.
Apr8-08, 06:17 AM   #50
Recognitions:
No. please look at your images again.
y axis goes up, x axis goes to the right. It is the most used convention.
Apr8-08, 12:22 PM   #51
Yes, sorry it was typo. So how is possible that for one value of beta particles, to have 2 kinetic energies for the electrons?
Thread Closed
Similar discussions for: beta particles
Thread Forum Replies
Penetration of beta particles High Energy, Nuclear, Particle Physics 7
Beta particles experiment High Energy, Nuclear, Particle Physics 2
alpha and beta particles Introductory Physics Homework 3
Global particles, local particles (Colosi, Rovelli) Beyond the Standard Model 0
Bombarment of beta particles against a alpha target General Physics 1
