Find Optimal Beam Dimensions for Supported Footbridge | Material Selection
The discussion revolves around determining the optimal dimensions for a beam in a simply supported footbridge spanning 7 meters, subjected to a distributed load and its own weight. Participants are exploring the implications of the beam's weight on bending moments and stress calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the bending moment as a function of distance along the beam and seeks to ensure that the maximum stress does not exceed a specified yield strength. Some participants question the calculations related to the beam's weight and its distribution, while others suggest treating the beam as uniform for weight considerations.
Participants are actively discussing the calculations and assumptions involved in determining the maximum bending moment and stress. There is an acknowledgment of potential errors in the original poster's calculations, particularly regarding the treatment of the beam's weight. Guidance has been offered regarding the correct approach to consider the weight of the beam in the calculations.
There is mention of a safety factor applied to the yield strength, and participants are navigating the complexities of using different unit systems in their calculations.
danago
A simply supported footbridge is to span a total of 7 meters. The load on the beam is a distributed force of 5kN/m plus its weight. Taking into account the beams weight, what dimensions should be selected for the beam?
Ive been given a table of beam dimensions along with their values for elastic modulus, second moment, measurements of mass per length etc.
I started by coming up with a the bending moment as a function of x, the distance from the end of the beam:
[tex] M(x) = \left\{ {\begin{array}{*{20}c}<br /> {(17.5 + 0.5W)x - 2.5x^2 } & {x \in [0,3.5)} \\<br /> {3.5W + (17.5 - 0.5W)x - 2.5x^2 } & {x \in [3.5,7]} \\<br /> \end{array}} \right.[/tex]
Where W is the wight of the beam.
I then found that the maximum bending moment occurs at x=3.5, so:
[tex] M_{\max } = 30.625 + 1.75W<br /> \]<br /> <br /> Given this, i want to choose a beam with dimensions such that the maximum stress in the beam does not exceed the yield strength, where the maximum stress is given by:<br /> <br /> [tex] \sigma _{\max } = \frac{{M_{\max } y_{\max } }}{I} = \frac{{M_{\max } }}{z}[/tex]<br /> <br /> Where z is the elastic section modulus. In this case, i will assume the maximum yield stress to be 60% of the actual yield stress, as in my mechanics class we are generally told to use a safety factor of 0.6. <br /> <br /> [tex] \sigma _{\max } = 150MPa = 150 \times 10^6 Pa[/tex]<br /> <br /> With these restrictions in place, i should find an elastic section modulus such that:<br /> <br /> [tex] z \ge \frac{{M_{\max } }}{{\sigma _{\max } }} = \frac{{30625 + 1750W}}{{150 \times 10^6 }}[/tex]<br /> <br /> Now my table gives values for z in the units mm^3, so i converted it to mm^3 by multiplying by 1000^3.<br /> <br /> [tex] z \ge \frac{{612500 + 35000W}}{3}[/tex]<br /> <br /> Now the table gives different values for the beams mass per unit length (kg/m), so i can calculate the weight of different beams and then put it into the equation above, but everytime i do so, i get answers that seem way too high. <br /> <br /> Does anyone have any input? I am not even sure if I've approached the question in the correct way. I think what's causing me problems is the fact that the weight isn't neglected like most other problems i need to solve.[/tex]
I haven'y checked your numbers, but your calc for the moment caused by the weight of the beam is wrong. The max moment caused by the beams weight is not WL/4 as you have calculated, but rather, WL/8 (the beam's weight may be considered concentrated at mid point when determining end reactions, but when considering internal stresses and moments, you must distribute it over the length of the beam. ). Otherwise, your approach looks OK, check your numbers, the SI metric system in engineering leaves me cold , since I use only standard USA units.
So when working with the weight, should i treat the bar as being uniform, so that the weight per unit length is given by W/7 N/m ?
Yes, where W is the total weight of the beam, in Newtons (If w is the weight per unit length of the beam, W=wL, and M_max, from the beam weight alone, is WL /8 or wL^2/8).
Ahh ok that helps :) Thanks very much.
  • · Replies 16 ·
  • · Replies 30 ·
10K
10K
