Can Machine Gun Bullets Propel a Vehicle to Required Speeds?
  • Thread starter Thread starter bcjochim07
    Momentum Vehicle
The discussion centers on calculating the number of bullets required to propel a 100 kg test vehicle to a speed of 19.0 m/s using a machine gun. The vehicle, equipped with a sail made of ultrahard steel, is tested on frictionless rails. The analysis reveals that each bullet, weighing 20.0 g and traveling at 400 m/s, exerts an impulse of -10 Ns upon rebounding at 100 m/s. To achieve the desired speed within 30 seconds, the calculation concludes that 6.33 bullets must be fired per second.
  • Understanding of momentum and impulse concepts
  • Familiarity with basic physics equations, specifically p=mv and J=change in momentum
  • Knowledge of unit conversions, particularly between grams and kilograms
  • Ability to perform calculations involving rates and time
  • Study the principles of impulse and momentum in physics
  • Learn about the mechanics of projectile motion and its applications
  • Explore advanced calculations involving frictionless systems
  • Investigate the implications of using kinetic energy in propulsion systems
Physics students, engineers involved in propulsion systems, and military strategists interested in innovative vehicle propulsion methods will benefit from this discussion.
bcjochim07
The Army of the Nation of Whynot has a plan to propel small vehicles across the battlefield by shooting them, from behind, with a machine gun. They've hired you as a consultant to help with an upcoming test. A 100 kg test vehicle will roll along frictionless rails. The vehicle has a tall "sail" made of ultrahard steel. Previous tests have shown that a 20.0g bullet traveling at 400 m/s rebounds from the sail at 100 m/s. The design objective is for the cart to reach a speed of 19.0 m/s in 30.0 s . You need to tell them how many bullets to fire per second from the machine gun. Note that your answer should be a rate, which can be fractional, rather than a quantity, which must be an integer.
p=mv J=change in momentum
I found the impulse exerted on a bullet.
J=(.02kg)(-100m/s)-(.02kg)(400m/s)
J= -10 Ns
Then I set up an equation to find what impulse needs to be exerted on the cart to speed up to 19 m/s:
0kgm/s + J = (100kg)(19 m/s)
J=1900 Ns
Then I assumed the impulse exerted on a bullet is the same as the impulse exerted on the sail by a single bullet :
1900Ns* (1 bullet/10Ns) =190 bullets
I then divided that by 30 sec. & came up with 6.33 bullets/sec.
Is this correct?
Your math is correct and I ran through your procedure and it looks sound.
… Because … Because … Because … !
The Nation of Because regards your militaristic experiments as a threat to our beliefs! :frown:
The ancient Nation of Because will always defeat the Nation of Whynot!
:mad: Go to your room! :mad:
19K
