Calculation of the band structure of Si
The discussion revolves around the calculation of the band structure of silicon (Si) using the pseudopotential method. Participants are seeking guidance on how to perform these calculations, particularly in the context of Monte Carlo simulations for transport processes. The conversation includes requests for programming resources and references, as well as clarifications on the necessity of full band structure calculations.
  • Homework-related
  • One participant requests help with calculating the band structure of Si using the pseudopotential method and expresses frustration over the lack of concrete resources.
  • Another participant provides a link to a resource and a reference to a journal article, but acknowledges it may not meet the original poster's needs.
  • A later reply questions the necessity of calculating the full band structure if existing data could be used for the Monte Carlo simulation.
  • One participant mentions their expertise and suggests that the method of calculation depends on the intended use of the band structure.
  • Another participant argues that a full band structure calculation is not necessary for calculating transport coefficients in Si and recommends a \vec{k} * \vec{p} approach instead.
  • There is mention of historical work by specific researchers that could provide insights into the transport properties of Si.
Participants express differing views on the necessity of a full band structure calculation for the intended Monte Carlo simulations. Some argue that existing band structure data could suffice, while others maintain that a full calculation is essential for accuracy.
Participants reference various methods and approaches, indicating that the discussion is influenced by differing levels of expertise and specific project requirements. There is also mention of the complexity involved in the calculations and the potential for varying interpretations of the necessary methods.
This discussion may be useful for researchers and students involved in semiconductor physics, particularly those interested in band structure calculations and transport phenomena in materials like silicon.
Dmitry
Please, help me to calculate the band structure of Si using the pseudopotential method. I will appreciate if you send me a simple program of calculation in any programming language very much and will be very grateful for any link or reference. The problem is than I've read the pile of books and haven't found anything concrete, everyting is too vague. Thanks!
Try this:
http://www.research.ibm.com/DAMOCLES/html_files/numerics.html#compbnd
and
M Elices et al., J. Phys. C: Solid State Phys. v.7, p.3020 (1974).
Zz.
Thanks, ZapperZ!
Thanks, ZapperZ, but this page is not exactly what I need. For now it would be enough for me to calculate without nonlocal contribution and spin-orbit interaction. I am looking for something more simple. Anyway, you are right, I need this calculation for Monte-Carlo simulation. And again, I need something more specific.
As for the Solid State Phys. article, I don't have the opportunity to get it. Maybe, if you have the electronic copy of it, you can help me a lot by sending it to me by e-mail: dima_r@pisem.net. Thank you!
Just what are you needing the full band structure calculation for? I have some expertise in this area and find that method of calculating the band structure depends on the calculation to be performed later.
dt
Thanks for your interest!
I need the full band structure calculation for Monte Carlo simulation of transport process.
For the beginning I need something simple enough, and then I will improve the calculation.
OK, so now *I* am confused.
If all you wanted to do is to simulate the transport process, then why can't you just USE the already available band structure for Si rather than actually calculating it? I initially thought that this is your whole project since this is already a daunting task by itself. But if you really have to do this, and then in turn, use Monte Carlo to solve something like the Boltzmann transport equation, I want to know who is the sadist who is forcing you to do all this!
Zz.
Well, you are right - he is a sadist! He is my supervisor of studies. There is a project to create a Monte-Carlo device simulation program. We were using the quadratic energy-wavevector relation with nonparabolicity and decided to improve the accuracy. My task is to write a module for the full band structure calculation. I think my supervisor has underestimated the difficulty of this task and overestimated my abilities.
You do not need the full band structure calculation to calculate the transport coefficients in Si, believe me I know. You only need to do a [tex]\vec{k} * \vec{p}[/tex] calculation. Include the nonparbolicity of the bands by including the off diagonal terms in the matrix. My advisor and his collaborators calculated the Hall and conductivity mobilities in Si about 20 years ago, look for papers by Frank L (F.L.) Madarasz or Frank Szmulowicsz in the 1983-86 timeframe. I extended this framework to anisotropic semiconductors for my dissertation, although money and time kept me from finishing the complete study.
The long and short of it is that the Boltzmann equation should mot be solved using Monte Carlo, but using the methods in my advisors papers. They have been quoted in the open literature as "definitive", the problem is that no one wants to do the problems correctly. Send me a private message and we can discuss it offline if you wish.
dt
