Am I on the right track with all of these
  • Context: Graduate
  • Thread starter Thread starter OptimusPrime
    Track
The discussion focuses on statistical concepts involving joint probability distributions and normal distributions. The joint probability distribution of Y1 and Y2 is given by f(y1,y2) = (2/5)*(2y1+3y2) for 0 < y1, y2 < 1. Participants derive marginal distributions, covariance, and correlation coefficients based on provided expectations and variances. Additionally, they analyze exam scores assumed to be normally distributed with a mean of 78 and variance of 36, calculating probabilities and grade cutoffs based on standard deviations.
  • Understanding of joint probability distributions
  • Knowledge of marginal distributions and covariance
  • Familiarity with normal distribution properties and calculations
  • Ability to compute standard deviations and correlation coefficients
  • Learn about calculating marginal distributions from joint distributions
  • Study covariance and correlation in the context of probability theory
  • Explore normal distribution tables and their applications in statistics
  • Investigate the implications of variance and standard deviation in data analysis
Statisticians, data analysts, students in statistics courses, and anyone involved in probability theory and statistical analysis.
OptimusPrime
1.Given the joint probability distribution of Y1 and Y2:
f(y1,y2)= (2/5)*(2y1+3y2), 0
0, elsewhere
find
a) f(y1) and f(y2) the marginal distributions
b) Given: E(y1y2) = 1/3 E(y1)=17/30, E(y2)=3/5
then Cov(y1,y2)=?
c) If E(y1^2) = 7/18 and E(y2^2) = 4/9 and E(y1)=17/30 and E(y2)=3/5
Find the correlation coeficcient. Comment on the strength of the correlation coefficient.
r(y1,y2)= Cov(y1,y2) / [Sd(y1) * SD(y2)]
So am I on the right track. Can anyone help me please?
a)
f(y1)=int(f(y1,y2),y2,0,1)
f(y2)=int(f(y1,y2),y1,0,1)
b)
Cov(Y1,Y2)=E(Y1Y2)-E(Y1)E(Y2)
Cov(Y1,Y2)=1/3-(17/30)(3/5)
c)
need SD(Y1) and SD(Y2)
V(Y1)=E(Y1^2)-[E(Y1)]^2
V(Y2)=E(Y2^2)-[E(Y2)]^2
so the correlation is weak.
2.Scores on an exam are assumed to be normally distrubuted with a mean of 78 and variance of 36
a) What is the probability that a person taking the exam scores higher than 75?
b) Suppose the student socring in the top 10% of this distribution are to receive an A grade, what is the minimum score that a student must achieve to earn an A grade?
c) What must be the cut off point for passing the exam if the examiner wants only 30% of all scores to be passing?
d) Approximately, what proportion of the students have scores 5 or more points above the score that cuts off the lowest 25 %?
This is what I did.
All: Mean = 78
All: Variance = 36, then Standard Deviation = 6
a. (75-78)/6 = -1/2 -- That is one-half standard deviation below the mean. I get 80.85%
b. find a score, S, such that (S - 78)/6 = 1.2815516.
S= 1.28*6+78
c)have to Find the 70th percentile of the standard normal distribution and translate to a grade.
d) have to find the first quartile (25th percentile) of the standard normal distribution, translate to a grade, and add 5 points
Any help would be appreciated
tHANKS!
0, elsewhere
find
then Cov(y1,y2)=?
a)
Yes, that's the right definition (assuming you meant that y1 and y2 are between 0 and 1. What did you get when you actually integrated?
b)
I haven't checked your calculation but that looks good.
c)
OK
This is what I did.
All: Mean = 78
When I check a table of "Normal Distribution" values (http://people.hofstra.edu/faculty/Stefan_Waner/RealWorld/normaltable.html is a good one), I get that the area under the curve, from 0 to 0.5 is 0.1915 and so this should be 69.15%, not 80.85%. You seem to have subtracted .1915 from 1 which would be the percentage of scores above 78+3= 81 or below 78.
S= 1.28*6+78
yes, that's what I get.
Yes. Again, 70% corresponds to z= 0.52 approx. What grade, S, is that?
The table tells me that the area under the normal curve from 0 to .675 (approx) is 0.25. By symmetry, the area from -infinity to -.675 is 0.25 so the first quartile corresponds to z= -.25. S= 78+ 6(-.25)= 76.5. 5 points above that is 81.5.
tHANKS!
Having typed all this in, I got an error message saying "The message you have entered is too short. Please lengthen your message to at least 10 characters."! Well, this is more than 10 characters right here, isn't it?
