| Thread Closed |
Magnetics of transformers and induction in metals |
Share Thread | Thread Tools |
| Apr2-08, 02:40 PM | #1 |
If you have the primary and secondary coils of a transformer next to each other, then current will induce a voltage in the secondary coil, creating current flow. This question applies to motors as well. If I place a sheet of steel between the two coils, will I still induce a voltage? For example, say I have a steel pipe and inside the pipe I place a secondary coil of wire. Outside the pipe I place a primary coil. Can I induce a voltage in the secondary coil through the steel pipe?
| Apr2-08, 02:49 PM | #2 |
The answer is yes, with a lot of qualification. How much induced voltage you get will greatly depend on specific geometry of the steel, the type of steel, the coil geometries, frequency, etc.
And, it's the changing B field that induces the voltage in the secondary, not the current. |
| Apr2-08, 02:52 PM | #3 |
Thanks. I guess I worded the question incorrectly. I meant the current in the primary coil. Thanks again!
| Apr2-08, 03:13 PM | #4 |
Do you have a specific problem in mind?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Magnetics of transformers and induction in metals
| Variation of magnetic flux density on a magnetic pipe | General Physics | 0 | ||
| Magnetics | Introductory Physics Homework | 1 | ||
| Magnetics | Introductory Physics Homework | 6 | ||
| Magnetics Questions | Introductory Physics Homework | 9 | ||
| Red Hot Magnetics | General Physics | 4 | ||
