How Do You Calculate Jet Speed, Momentum, and Forces in Physics Problems?
  • Thread starter Thread starter zephyrus777
The discussion revolves around calculating jet speed, momentum, and forces related to a jet of water from a fire hose and a collision scenario involving two cars. The problems involve concepts from fluid dynamics and momentum conservation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the use of conservation of energy to determine the minimum speed of water needed to reach a certain height. There is also an attempt to apply momentum conservation in the context of a collision between two cars.
Some participants have provided guidance on using conservation of energy for the water jet problem, while others are attempting to derive equations related to the collision scenario. There is an ongoing exploration of the relationships between variables, but no consensus has been reached on the solutions.
Participants express uncertainty about the calculations and the relationships between the variables involved, particularly in the context of the equations provided. The original poster indicates confusion regarding the initial conditions and the expected outcomes.
zephyrus777
A jet of water from a fire hose is capable of reaching a height of 20m. What is the minimum speed of water from the hose? Given the area of cross section of the hose outlet is 4 x 10^(-4) m squared . calculate
a) The mass of water leaving the hose each second.
b)The momentum leaving the hose each second
c) the force on the hose due to the water jet. the density of water is 1000 kg/m cube
f= dmv/dt
f= v x (dm/dt) (d is delta/small change)
P=mv
I got stucked on first part.. no idea at all how to get the speed to 20 m/s (answer from my book says so :( )
2) A car of mass 1200 kg traveling at high speed collides with a stationary car of mass 800kg. The two cars lock together on impact and slide a distance of 120m before stopping. Tests on the road surface show that the frictional force in the slide was 0.2 x the weight of the vehicles. Calculate
a) The decceleration of the two vehicles after impact.
b) the speed of the two vehicles immediately after impact.
c) the speed of the 1200kg car just before impact.
m1u1 + m2u2 = (m1 + m2) v
the four linear dynamics equation..
1200(u1) + 800(0) = (1200+800) v
then i make v as the subject and subtitute into the linear equations.. i got stucked as i got the equation in multiple terms and can't be simutanous equated.
thanks in advande for answering my questions, hopefully :D
Use conservation of energy. Just to fix the notation:
Let [itex]m[/itex] be the mass of water leaving the hose.
Let [itex]v[/itex] be the velocity of the water leaving the hose.
Let [itex]h[/itex] be the maximum height that the water reaches.
Taking the location of the hose to be [itex]y=0[/itex], can you write down the law of conservation of energy for this problem?
1/2 m v^2 = mgh , when h= 20, find v.. oh thanks dude :D
how bout (b) :( sigh..
That should be easy. You know v and you know the cross sectional area of the nozzle. That's all you need.
