| Thread Closed |
Thermodynamics - Steam and Two Phase Systems |
Share Thread |
| Apr4-08, 06:30 AM | #1 |
Steam at a pressure of 1.25 MN/m² and with a dryness fraction of 0.96 flows through a steam mains of 150mm diameter with a velocity of 26 m/s. The steam is throttled to 0.12 MN/m². After throttling, 5kg of steam is blown into a tank of 98kg water, the original temperature of which is 16ºC. Take the specific heat capacity of steam at constant pressure to be 2.09 kJ/kg K and neglect heat losses.
Determine (a) mass flow rate of steam through the mains in kg/s [Answer = 3.04 kg/s] (b) temperature of steam after throttling [Answer = 115.1ºC] (c) temperature of water in the tank after receiving 5kg blown steam [Answer = 48.54ºC] STEAM TABLES Extract (Use for solution) P = 0.12MN/m² , Saturation Temperature = 104.8ºC, hf = 439.4kJ/kg, hfg = 2244.1kJ/kg, Specific volume = 1.478 m³/kg P = 1.25MN/m² , Saturation Temperature = 189.8ºC, hf = 806.7kJ/kg, hfg = 1977.4kJ/kg, Specific volume = 0.1569 m³/kg |
| Thread Closed |
Similar discussions for: Thermodynamics - Steam and Two Phase Systems
| Differences between 3phase and 6 phase systems | Electrical Engineering | 2 | ||
| Phase, Phase Difference and Phase Shift | General Physics | 6 | ||
| Thermodynamics-Steam Turbine | Advanced Physics Homework | 0 | ||
| Thermodynamics of steam | Introductory Physics Homework | 4 | ||
| Thermodynamics: Phase-change refrigeration | Advanced Physics Homework | 2 | ||
