| New Reply |
If no singularity, what’s inside a big black hole? |
Share Thread |
| Sep11-11, 06:54 PM | #52 |
| Sep11-11, 07:54 PM | #53 |
BTW, maybe its not appropriate here, but I went to a talk a few days ago where the Nasa speaker said there may be far distant black holes with up to 10^12 solar masses. If true, thats about the equivalent of 1000 Milky Ways. Wow.
| Sep12-11, 12:16 AM | #54 |
Recognitions:
You only need a rough estimate. The black hole evaporation time for a black hole of one solar mass (calculated based on Hawking radiation - which is definitly incorrect as soon as the hole becomes smaller and has Planck size) is approx. 1067 years. Now think about an observer not located at infinity but e.g. at the earth orbit. The result is approx. the same (the gravity of the sun at the earth orbit is small, therefore time dilation due to the gravitational field is very small). And now think about this observer falling into the black hole. It will definity take less than 1067 years ... http://en.wikipedia.org/wiki/Hawking_radiation |
| Sep12-11, 12:43 AM | #55 |
tom.stoer, I think what genneth is getting at is that near the event horizon, gravitational time dilation increases without bound.
http://en.wikipedia.org/wiki/Gravita...otating_sphere No matter how long it took for the black hole to evaporate, there is some finite distance from the event horizon where you would experience this time to be very short. Think about it this way. As you fall into the event horizon, the Hawking radiation from the black hole is blue-shifted to such a high energy that it appears that the black hole is evaporating very quickly. The statement 'you would not notice anything while falling into a large black hole' is not technically true. I would hardly call being blasted by intense gamma radiation, increasing in energy to infinity, 'not noticing anything'. Of course, this is just a re-stating of the trans-Planckian problem. Which indicates the difficulty current physics has with event horizons. There are proposed solutions of course, fuzzball being one of them. At the end of the day you need some form of quantum gravity to explain event horizons adequately. |
| Sep12-11, 01:44 AM | #56 |
Recognitions:
Have you ever made a single calculation in general relativity by yourself? |
| Sep12-11, 12:07 PM | #57 |
Consider the following statements, and tell me where the logic goes off the rails: 1. An asymptotic observer never sees an infalling observer cross the event/dynamical horizon. 2. The horizon evaporates in a finite time. 3. The asymptotic observer will see the infalling observer still there after the horizon evaporates. 4. Therefore from the asymptotic observer's point of view, she doesn't cross the horizon either, and will live to see it completely evaporate. This calculation can indeed be pushed all the way until the semi-classical approximation breaks down, and I think it's correct. I think this paper by Krauss (http://arxiv.org/abs/gr-qc/0609024 or Phys.Rev.D76:024005,2007) says the same thing, though I'm not sure I entirely agree with the details (event horizon vs. dynamical horizon, and therefore the interpretation). (Btw, I am in no way invested in the original genesis of this problem --- I just think this scenario is worth thinking about as a thought experiment and might be informative on matters in general, not necessarily including the issue of what replaces a singularity...) |
| Sep12-11, 12:32 PM | #58 |
Only thing that occurs to me is that is would appear this argument requires the the two observers see the same event as though it were happening at the same time for both of them. I'm not sure I've said that right, but my point is that it seems to merge the two reference frames in a way that is not correct.
| Sep12-11, 01:50 PM | #59 |
Recognitions:
The general flaw is that you mix two scenarios, namely arguments for a static spacetime with arguments for a dynamic spacetime with an evaporating BH. The third flaw is that you don't calculate (or believe) what the infalling observer will actually see. The free-fall time is much smaller than the evaporation time. |
| Sep12-11, 02:41 PM | #60 |
| Sep12-11, 05:38 PM | #61 |
Recognitions:
OK, maybe there is a "horizon-issue", but only in the sense that there is an underlying microscopic structure to classical spacetime.
Or do you think that classical GR (to which I refer when I am talking about free fall, proper time etc.) will no longer be valid outside the horizon for large black holes? Of course we expect that the evaporation will change, but we do not expect any "quantum effects" for classical motian, do we? |
| Sep12-11, 05:58 PM | #62 |
However, even though the blue-shift would not be infinite, it would still happen. It still remains that a theory of quantum gravity is needed before a definitive answer can be given. This paper talks about this subject at length: http://arxiv.org/abs/0806.0628 |
| Sep12-11, 07:16 PM | #63 |
Recognitions:
| Sep13-11, 01:51 AM | #64 |
Recognitions:
Details about the small corrections due to quantum gravity cannot change this conclusion, which is why the information loss paradox is one of the greatest unresolved problems in theoretical physics. It isn't some mere detail of quantum gravity to be determined by future generations but rather the type of clash (like the UV catastrophe) that signals a theoretical underpinning must be altered (which qg must thereafter explain in detail microscopically) So in a sense the answer is yes, the classical theory most likely is incomplete (even macroscopically), or rather it appears necessary for there to be a complementarity between descriptions and/or a dual holographic formulation that rescues us from what would otherwise be an absurdity. |
| Sep13-11, 02:02 AM | #65 |
At any rate, issues of singularity resolution at the center appear to be a red herring to this problem, it is not the relevant question to ask. |
| Sep13-11, 02:15 AM | #66 |
Recognitions:
So how big roughly would the macroscopic effects be at the horizon? If say a 70 kg person fell through the event horizon of a large black hole, would he notice anything like a fuzzball?
| Sep13-11, 02:24 AM | #67 |
| Sep13-11, 09:48 AM | #68 |
EDIT.: Just noticed what suprised said above. So, what I mean is a killer fuzball. |
| New Reply |
Similar discussions for: If no singularity, what’s inside a big black hole?
| What's inside a black hole? | Special & General Relativity | 26 | ||
| Black hole inside a larger black hole. | Cosmology | 33 | ||
| singularity of a black hole | Special & General Relativity | 0 | ||
| singularity of a black hole | General Astronomy | 1 | ||
| discernment , duality and perception ,singularity (not black hole) | General Discussion | 4 | ||
