What Is the Phase Angle of a Wave Traveling on a String?
The phase angle of a transverse sinusoidal wave traveling along a string in the negative x-direction with an amplitude of 5 cm is calculated using the equation φ = arccos(x/A). Given that at time t=0, the displacement at x=0 is 4 cm, the phase angle is determined to be 36.87 degrees. However, due to the negative acceleration and positive velocity, the correct phase angle is adjusted to 323.13 degrees. It is crucial to apply wave equations for accurate results, as the basic harmonic motion equations may not yield reliable outcomes.
  • Understanding of sinusoidal wave properties
  • Familiarity with trigonometric functions, specifically arccosine
  • Knowledge of wave equations, particularly y = A sin(k*x - ω*t + φ)
  • Basic concepts of simple harmonic motion (SHM)
  • Study wave equations in detail, focusing on y = A sin(k*x - ω*t + φ)
  • Explore the relationship between phase angle and wave properties
  • Learn about the implications of negative acceleration and positive velocity in wave motion
  • Review examples of phase angle calculations in various wave scenarios
Students studying physics, particularly those focusing on wave mechanics, as well as educators and anyone seeking to deepen their understanding of phase angles in wave motion.
physicsgrouch
A transverse, sinusoidal wave is traveling along a string. It moves in the negative x-direction, and it has an amplitude of 5 cm. At time t=0, the point at x=0 is at a displacement of 4 cm and is traveling upward. What is the phase angle in degrees?
x = A*cos([tex]\omega[/tex]*t+[tex]\phi[/tex])
At t=0, [tex]\omega[/tex]*t = 0, so x = A*cos([tex]\phi[/tex]). Therefore, [tex]\phi[/tex] = arccos(x/A) = arccos(.8) = 36.87.
The acceleration is negative and the velocity is positive, so the angle is 360 - 36.87 = 323.13 degrees, right?
The equation you just used is not trustworthy for waves.It can be only generalized to SHM.
You must use wave equations to be more sure in your answers.
y= A sin ( k*x-omega*t + phase angle)
  • · Replies 23 ·
