New Reply
What happens to light when it reaches the edge of the universe?
Share Thread Thread Tools
May1-04, 07:31 PM   #18
Quote by hitssquad
The universe's three dimensional space is curved back on itself in the same way that the 2-dimentional surface of the earth is curved back on itself. If you keep walking in one direction on Earth, eventually you will reach your starting point. Similarly, light travelling in one direction through the universe will eventually reach its starting point (if it travels long enough and outruns any expansion of the universe).
if this was the case, would the darkness of space even exist? wouldnt there be everlasting light in every single direction at every single point of time?
May1-04, 08:44 PM   #19
Quote by fbsthreads
it couldn't keep on travelling into nothingingness could it? becuase that nothingness would be space.
it couldn't reflect off something unless there was matter at the edge to reflect off.
the light must do something, it can't disappear can it? that would contradict the 'can't create or destory energy' law.
What happens to the value of a fraction as its denominator approaches infinity? This is the same thing that happens to light - but at a rate inverse to dist^2.
BTW...what makes you think the Universe has an edge? And what is on the other side of that edge?
May2-04, 02:29 AM   #20
I ment dr/dt ofcourse, pardon.
May2-04, 10:07 AM   #21
I thought that with new experiments revealing the density of the universe it was exactly enough for a flat universe, not a curved one.
May2-04, 10:20 AM   #22
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by cangus
In a closed universe, only if the expansion were slower than c.
May2-04, 10:22 AM   #23
Recognitions:
Quote by Matrixman13
The question as to whether the universe is open or flat is still ... open It shouldn't be surprising if this is still under some debate 50 or 100 years from now ...
May3-04, 03:27 PM   #24
Recognitions:
Quote by cangus
Not if the expanding universe was finite in age (light from distant objects may not have reached you yet).
May3-04, 03:37 PM   #25
Recognitions:
Quote by fbsthreads
but if it is accelerating all the time then there must have been a time when light could easily reach the edge.
also, if big bang is to be believed then any light from the big bang 'explosion' would have been at the edge of the small universe in no time.
In a closed universe, you may get a situation like hitssquad mentioned (space being curved such that the light beam reaches its starting point and goes around again).
In an open or flat universe, space is infinite (or at least boundless), so there is no edge. Offhand, I'm not quite sure how that works at the instant following the Big Bang...infinite space from the very beginning I think (or a temporary closed topology?)
if light could never reach the edge, you could still see the big bang if you were at the edge.
In any of the models (closed, open, flat) there is no edge. The Big Bang was not an explosion of matter/light/energy into empty space. It was the rapid expansion of all of existance.
The Big Bang happened about 13.7 billion years ago & due to the finite speed of light, we could see the Big Bang if we could see 13.7 billion light years away (we can get close with current technology, but not that close). But if we were to magically transport ourselves 13.7 billion light years away, we would not be in the middle of the Big Bang. Things would look there as they do here because time has passed there too.
May4-04, 05:01 PM   #26
Recognitions:
An infinite unievres must of always been infinite, at the big bang in an infite unievres, you basically have an inifte, but infinitely dense space, which expands (in other words becomes less dense).
The universe is flat within experimental error, no-one is ever going to be able to say it's completely flat as that means measuring it's curvature precisely. Many of the interesting new cosmologies that make the mainstream media, (like for example the 'soccer ball' universe) have a curvature that is within the experimental error of the measured value, but are not flat. Flat unieverses needn't be infinite in space, howver I've been told that topologies which give flat finite universe are extremely non-trivial so the bog-standard infinite topology must be preferred.
The problem with phrases like an 'open universe' is technically it refers to a Friedmann-Lemaitre universe whioch is infinite in space and with either negative or Euclidian (i.e. no) curvature, that will contiune to expand forever. An open universe is an example of an 'open space' which is a infite space with no boundaries. It's gets even more confusing as people sometimes use the word 'open', rightly or wrongly to refer to other kinds of cosmologies that shares certain features with a Friedmann-Lemaitre open universe.
May4-04, 09:29 PM   #27
It is possible for objects in the visible universe (with respect to some obsever) to have recession velocities faster than the speed of light,...
This is a little confusing to me - I thought it was not possible for any object with a real rest mass to have a velocity equal to the speed of light, let alone exceed it.
May4-04, 10:19 PM   #28
Recognitions:
Take a look in the General Astronomy & Cosmology sticky (A&C reference library); there are several papers which cover this topic, in considerable detail. Look for "Lineweaver".
May5-04, 05:58 AM   #29
Quote by fbsthreads
What do you not understand? The universe has no edge, regardless if it's closed or not.
May5-04, 07:22 AM   #30
Recognitions:
Quote by geometer
There's a difference between velocity and recession velocity, it's only in special relativity that the observed velocity will be the same as the relative veloctiy with respect to c. In general relativity your dealing with spaces that aren't Euclidian and that have a dynamic geometry and special relativity becomes the local case only. Recession velocity isn't due to any actual movement of the objects themselves, but the expansion of spacetime, so there is no barrier to it being greater than c.
May7-04, 03:13 PM   #31
Space curvature is nice, but to really understand how things work you need to know whats going on at the quantum level, which is anyones guess.
meemoe_uk's law is a simple idea which deals with the edges of space with QM.
- every traveling quantum must have a start and end point
so no light can be sent off the edge on an infinate journey.
Quasars are the most distant objects we can detect, so they are our current best bet for 'objects on the edge'. By meemoe_uk's law, all their radiation must be transmitted back into the universe. This of course makes them seem to radiate much more intensely then we'd expect if we thought their radiation was free to fly off in any direction. Also this may explain why the universe appears to expand. Galaxys and quasars effectively have radiation thrusters which accelarate them into the least dense space, in the case of quasars this is off the edge of the universe! lol
May7-04, 11:09 PM   #32
Quote by Flatland
Some people tend to overlook the fact that the very premise of their argument is flawed. Be patient.
May16-04, 06:58 PM   #33
Recognitions:
there is no 'edge' of the universe. only spatially bound objects have edges and the universe in not an 'object'.. it is all of spacetime. to think of it as an object requires the existence of non-object regions [i.e. spacetime continuums that originated independent of our universe]. it also requires them to interact [have observable effects] with this universe to be of any theoretical consequence. we have not yet observed any phenomenon in this universe that require the existence of other universes to be explained.
there is however a theoretical limit to the observable universe. hubbles constant predicts objects at a distance around 15 billion light years would be receding at the speed of light. we could therefore say the observable universe is a sphere 30 billion light years in diameter. of course, you would arrive at this same conclusion no matter where you were in the universe. this imaginary edge only exists in your local reference frame. under general general relativity, no matter where you are or what speed you travel, the 'edge' of the universe will always appear to be 15 billion light years [according to whatever clock you happen to have along] away from your current position. the long and the short of it is you cant get there from here, or from anywhere else for that matter.
May16-04, 07:47 PM   #34
Recognitions:
Quote by Chronos
...a theoretical limit to the observable universe. hubbles constant predicts objects at a distance around 15 billion light years would be receding at the speed of light. we could therefore say the observable universe is a sphere 30 billion light years in diameter...
Chronos you might enjoy reading "Expanding Confusion" by Tamara Davis. I will put a link, in case you want to.
http://arxiv.org./abs/astro-ph/0310808
It addresses some misconceptions about the expansion of the universe and the dimensions of what is observable.
You are right that there is a bound to the observable universe. But I dont think it is 15 billion LY.
Hubble's parameter has not been constant over time.
One cannot go by the present value of it.
Indeed, it turns out that
the light reaching us from many of the galaxies we see now was emitted at a time when that galaxy was receding from us at faster than the speed of light---and yet the light managed to reach us, curiously enough.
The Davis and Lineweaver article explains how this can be.
For example, galaxies are routinely observed at redshifts greater than 3.
In fact, one was recently detected to have z = 10 (by Roser Pello's group).
A galaxy observed at z = 3 must have been receding from us, at the time it emitted the light we are now receiving from it, at a speed greater than light.
using the standard "Sky and Telescope" calculator at S. Morgan's website
http://www.earth.uni.edu/~morgan/ajj...gy/cosmos.html
you can see that a galaxy observed with z = 3 would have emitted the light
when it was receding at 1.6 times c
and it would now be at a distance of 21 billion LY
and currently receding at a speed of 1.5 times c.
If you want to use the online calculator, put in 0.73 for dark energy (lambda)
and 0.27 for matter (omega), and z = 3 or whatever you want the redshift to be.
BTW it looks like you, flatland and Thor are all saying no edge to the U
and I can only say amen to that! I'm not certain myself there is even a back fence in the time direction , but for sure nobody I know thinks theres a spatial boundary
New Reply
Thread Tools
Similar Threads for: What happens to light when it reaches the edge of the universe?
Thread Forum Replies
Light Waves at Edge of Universe Question Astrophysics 13
What happends to light before it reaches us? General Astronomy 3
The edge of the universe General Astronomy 7
Why is the sky blue yet the light that reaches the earth white? General Physics 4
Spacecraft reaches edge of solar system: CNN General Astronomy 6
