Spot size and focal length lens
The discussion centers on the relationship between spot size and f-number (f#) in lenses, specifically how a lower f# results in a larger spot size. It is established that f# is calculated as f/D, where f is the focal length and D is the diameter of the aperture. A larger diameter (D) leads to a lower f#, which correlates with increased spot size. The conversation emphasizes that while the lens must focus within the detector's area, it does not need to match the detector's size precisely to avoid blurriness.
  • Understanding of lens optics and terminology
  • Knowledge of f-number (f#) calculations
  • Familiarity with aperture diameter and its impact on image quality
  • Basic principles of camera design and image sensors
  • Research the effects of aperture size on depth of field in photography
  • Explore lens design principles for optimal image sharpness
  • Learn about different lens configurations and their impact on spot size
  • Investigate the relationship between focal length and image resolution
Photographers, optical engineers, and anyone involved in lens design or image quality optimization will benefit from this discussion.
edmondng
why does the spot size increase with lower f#.
Lets says you have 2 lens of the same material, and diameter, just different focal length. F/2 has higher spot size than F/3 but F/2 is faster. Is spot size a characteristic of a lens? So if your detector is fixed in size you need to get a lens that fits about the size of your detector or less otherwise it will result in blurry image?
f# = f/D, where f = focal length, and D = diameter of aperture. This diameter IS essentially your spot size. Therefore bigger D = lower f#
Yes and No. It depends on the aperture-lens configuration - If we're talking about camera's its not something major to worry about because it's always designed optimally.
Your lens doesn't need to "fit" the size of your detector but rather focus down to within the detectors area.
