Discontinuities of coefficient in linear homogeneous system
The discussion centers on the analysis of the Wronskian for the functions \( x^{(1)} = \begin{pmatrix} 1 \\ 1 \\ 1 \end{pmatrix} \), \( x^{(2)} = \begin{pmatrix} 1 \\ t \\ t^2 \end{pmatrix} \), and \( x^{(3)} = \begin{pmatrix} 1 \\ t \\ t^3 \end{pmatrix} \) within a linear homogeneous system defined by \( x' = P(t)x \). The Wronskian is calculated as \( W = t^4 - 2t^3 + t^2 \), which factors to \( t^2(t-1)^2 \), indicating discontinuities at \( t = 0 \) and \( t = 1 \). These discontinuities in the Wronskian suggest that the coefficients \( p_{i,j}(t) \) in the matrix \( P(t) \) are undefined or discontinuous at these points, preventing the extension of solutions beyond these values.
  • Understanding of Wronskian determinants in linear algebra
  • Familiarity with linear homogeneous systems of differential equations
  • Knowledge of matrix theory and properties of determinants
  • Basic calculus, particularly in evaluating limits and continuity
  • Study the properties of the Wronskian in differential equations
  • Learn about discontinuities in matrix coefficients in linear systems
  • Explore the implications of the Wronskian being zero on the uniqueness of solutions
  • Investigate the behavior of solutions near points of discontinuity in \( P(t) \)
Students and researchers in mathematics, particularly those focusing on differential equations, linear algebra, and systems theory, will benefit from this discussion.
jessawells
let [tex]x^{(1)} = \left( \begin{array}{ccc}1\\1\\1\end{array} \right)[/tex], [tex]x^{(2)} = \left( \begin{array}{ccc}1\\t\\t^2\end{array} \right)[/tex], [tex]x^{(3)} = \left( \begin{array}{ccc}1\\t\\t^3\end{array} \right)[/tex]
a) Find the Wronskian [tex]W(x^{(1)}, x^{(2)}, x^{(3)})[/tex]
b) You are told that [tex]x^{(1)}, x^{(2)}, x^{(3)}[/tex] are solutions of a
linear homogeneous system [tex]x' = P(t)x[/tex]
i) what can you say about the discontinuities of the coefficient [tex]p_{i,j}(t)[/tex]?
ii) Find [tex]p_{1,1}(t) + p_{2,2}(t) + p_{3,3}(t)[/tex]. (Hint: use your solution to part a).
W = determinant of [tex](x^{(1)}, x^{(2)}, x^{(3)})[/tex]
For part a), the Wronskian is W = determinant of [tex](x^{(1)}, x^{(2)}, x^{(3)})[/tex], which I found to be [tex]t^4 -2t^3 + t^2[/tex]. I'm not sure how to do part b). What discontinuities is the question referring to, and how do I find them? How do I use my answer to part a) to solve b)ii)? Any help is appreciated!
[itex]t^4- 2t^3+ t^2= t^2(t-1)^2= 0[/itex] when t= 0 or t= 1. Since such an equation has a unique solutions as long as the Wronskian is non-zero, what do you think prevents a solution from being extended past t= 0 or t= 1? It must be discontinuities in matrix P.
