Register to reply
Vinegar and stomach acid pH
by Simfish
Tags: acid, stomach, vinegar
Share this thread:
Simfish
#19
Dec25-10, 07:07 PM
PF Gold
Simfish's Avatar
P: 828
Then you seem to think that a weaker acid makes a stronger acid less acidic. No: the vinegar would have practically only the effect of the same volume of water. Apart from that effect, two acids together are more acid than either alone, not something in between.
Hm, this sentence confuses me. The extra volume of water would *definitely* dilute the acid. In other words, it would raise the pH. So if you added vinegar instead of water, you would still raise the pH (since the volume of vinegar would probably be a good fraction of the total volume of stomach acid, and since the vinegar is usually well-diluted anyways) of the whole solution - just not as much as if you just added water? (but still more than adding nothing at all?) There would be far more neutral water molecules with the extra addition, and just a few more hydronium ions (and the ratio of them would just decrease)
Proton Soup
#20
Dec25-10, 11:43 PM
P: 1,070
vinegar seems to affect digestion in a good way, so enjoy your vinegar.
http://www.ncbi.nlm.nih.gov/pubmed/9630389
http://www.ncbi.nlm.nih.gov/pubmed/16015276
as for how it affects stomach acidity on an empty stomach, that's hard to say. the stomach is not normally secreting much acid then. that's why you want to take calcium carbonate supplements with a meal: to dissolve the carbonate releasing CO2 and make the Ca++ ions available for absorption. otherwise, you pass much of it as sand. calcium citrate (like the citrical commercials paul harvey did aimed at your parents with low stomach acidity) you can take whenever.
http://en.wikipedia.org/wiki/Stomach_acid#Secretion
dreiter
#21
Dec26-10, 02:21 PM
P: 57
Quote Quote by Evo View Post
Oh, no, I mean actual nutrional analysis. One head of cabbage grown *organically*, one head of cabbge grown normally. Nutritionally they are identical.
Well a 0.18 second Google search found me just the article I needed, and it is only one of many I have seen. YES, organic produce is MEASURABLY healthier than conventional produce. I really don't understand why people are so hesitant to this idea.
"In summary, this analysis found more iron,
magnesium, phosphorus, and vitamin C and
less nitrates in organic crops as compared to
conventional crops. In addition, there were several trends showing less protein but of a better
quality, more nutritionally significant minerals,
and lower amounts of some heavy metals in
organic crops compared to conventional ones."
Jones3251
#22
Dec26-10, 04:16 PM
P: 3
If you have what you believe to be too much acid in your stomach that 2 tsp spoons of applecider vineger. If your stomach boilsthen use an antacid but most likely you will find that you acid is low and you need to increase the acid.
Also vegetables that are grown with commercial fertilizers, pesticides and gene spliting or other microbiaogie changes are lower in vitamins, minerals and are basicly nothing but fiber. How can you remove the nutriants from the earth and then find them in the produce.
If you want to feed the world on 2 acres of land by changing the DNA structure of the plant then something must suffer. Remember Newton's Law - For Every Action there is an equal and opposite reaction. The more you grow on that acre of land the less value it has.
Dream Relics
#23
Jan29-11, 12:17 AM
P: 1
Greetings. This is a very interesting thread. I came across it trying to find info about how to treat digestion problems and low stomach acid. I wish that I was better versed in chemistry and I can not speak at all to the debate about the chemistry of stomach ph and vinegar. However, I can offer this bit of information based on my own experience. Bragg's raw organic apple cider vinegar is delicious. I use it to mix up salad dressing with olive oil and a little seasoning or sometimes just plain.
The side discussion that ensued about the veracity of health food claims and organics vs conventional produce is also very interesting. First of all i must confess that I have no references to site. However, even if I did, that which I may have read, no matter how well referenced, is still only information and not truly knowledge if it did not come as the result of direct experience. (At least, that is what I think.) That being said, I believe there is a good deal of evidence that is mounting that can leads in the direction of concluding that modern style large scale farming that uses GM crops and all the pesticides is having a huge deleterious effect on the well being of wild life, soil health, water purity and that in fact the foods grown that way are less healthy and in my experience taste like nothing, or bad.
I eat almost all Organic veggies fruits and they really do taste better. Even if Pesticides had no bad effect on the foods themselves, the effect they have on the environment is an important consideration also.
lastly, I work at a Health food type store, and I have meet countless people who tell me that some health problem or another of theirs has gotten better because they changed they way they where eating. I understand that the science and understanding, from a fully tested point of view, of the interplay between diet and health is still quite nascent and there is much that is disagreed upon, but the basic ideas have been around for a long time. eat plenty of veggies. drink enough water. get exercise.
anyway. that is my 2 cents. I wonder if there is a thread on here about time travel.
Jones3251
#24
Jan29-11, 10:25 AM
P: 3
Again your are only looking at a chemical reaction not at the function of the apperatice. If you have low acid in your stomach you will have poor digestion which most people think is that they have too much but in most cases you don't have enough. If you injest ACV and you feel better then the problem is your stomach acid is low but if you feel whose and feel that you acid burning sensation then ACV is going to nothing for you. So if you stomach acid is low then ACV will increase the acidity in your stomach for a positive reaction but if you have a normal or high amount of acid then you will get a negative reaction. Remeber none of you are taking into acount the mechanics and chemical reactions of the human body. Physics and chemistry are only as accurate as the data input into the equation. Nothing is just black and whith.
By the way I have complete tested the reactions of this on myself long before to resolve my own issues which were sevier as I have mutiple issues with the intestinal tract and malnutrition.
kagenical
#25
Jan30-11, 06:40 PM
P: 1
Guys, stop thinking like physicists. ACV induces the previously inert stomach into producing hydrochloric acid. Much of the acid production in the stomach occurs at the anticipation of food, along with the aroma and tastes of food.
Eating just about anything small enough before actually eating, especially an initially acidic food (such as lemon juice, which ends up being slightly basic after digestion), will make sure a large pool of acid and digestive enzymes is available for the real meal to come. Suspending the chyme in enough acidic fluid is important for proper and complete digestion preventing a bolus of food from forming and stalling somewhere down the line.
Simfish
#26
Jan30-11, 06:44 PM
PF Gold
Simfish's Avatar
P: 828
But then why can't you take certain medications (Adderall, Concerta, especially) with acidic food/drink? The acidity supposedly ruins the effect of these medications because it makes the stomach environment more acidic. The instructions still say that it's okay to take them with meals.
Evo
#27
Jan30-11, 09:18 PM
Mentor
Evo's Avatar
P: 26,537
Locked pending moderation.
Register to reply
Related Discussions
How does the stomach know to vomit? Biology 26
If you have a weak stomach don't click here General Discussion 20
Falling stomach General Physics 11
Vinegar and Soda Chemistry 5
