What is the speed of light measured relative to?
The discussion centers on the measurement of the speed of light and its implications in the context of special relativity. Participants explore questions regarding the relative speeds of light particles (photons) and other particles, the concept of reference frames, and the historical context of light measurement techniques.
  • One participant questions what the speed of light is measured relative to, suggesting a scenario where two light particles travel in opposite directions and wonders if this would imply a speed greater than light.
  • Another participant asserts that special relativity prevents any particle from exceeding the speed of light, emphasizing that this principle is central to the theory.
  • A participant references the Michelson-Morley experiment, arguing that it demonstrated the constancy of the speed of light regardless of direction, which contributed to the development of relativity.
  • One post details the historical methods used to measure the speed of light, including the use of rotating mirrors and the definitions of the meter and second, highlighting the circularity of defining the speed of light in terms of these measurements.
  • Another participant clarifies that photons do not have a reference frame, making it meaningless to discuss their velocities relative to each other, and introduces the concept of mutual velocity for massive particles moving at relativistic speeds.
  • There is a discussion about how light behaves near a black hole, with some participants suggesting it appears to slow down or change direction due to the curvature of spacetime.
  • One participant introduces the relationship between the speed of light and the permittivity and permeability of free space, indicating a physical basis for its speed.
Participants express differing views on the implications of light's speed and reference frames, with no consensus reached on the interpretation of relative speeds of photons or the nature of light's behavior in various contexts.
Some discussions involve assumptions about reference frames and the nature of massless particles, which remain unresolved. The historical context of light measurement is also complex, with dependencies on definitions that may not be universally accepted.
_Mayday_
Hey,
When the speed of light is measured, what is it's speed measured relative to? If I sent two speed of light particles in opposite directions, would the one particle be traveling at twice the speed of light, relative to the other one? I have a sneaky feeling this violates a law, which is something like addition of velocities or something like that. This is all a bit misty in my mind, could someone please help me sharpen it up.
_Mayday_
Science news on Phys.org
No, one particle would not be traveling faster than the speed of light. That's what special relativity is all about. I know that's not explaining the situation but special relativity is exactly about that fact.
I think that is why the "ether" could not be found. In the Michaelson-Morley experiment no matter in what direction you measured the speed of light, in your case it would be in the opposite direction, the speed of light remained constant. Einstein took that results and then reasoned out the theory of relativity.
Michaelson measured the speed of light (in terms of the standard of length and standard of time of the day) by measuring the round trip that light took to a mirror on some mountain about 22 miles away. he used a rotating mirroe contraption that, in the short period of time that it took for light to make the round trip, the mirror moved an amount and the return beam reflected off in a different direction than it would have if either the mirror did not move or if lightspeed was infinite. there is an adjustment made by measuring the ratio of the speed of light through air vs. a vacuum and that can be done in a lab with a vacuum chamber.
before 1960, the meter was defined as the distance between scratch marks on a platinum-iridium bar. and the second is (today) defined as a certain number of periods of some Cesium radiation. given those definitions, they had to measure the distance to the mountain in terms of that meter stick and the speed of the rotating mirrors interms of that time standard. so it would have been in terms of that meter and that second that they measured the speed of light against.
today, the meter is defined to be the distance that light travels in 1/299792458th second. so you can't use that definition of a meter to "measure" the speed of light, because of the circularity of that definition. you will always get 299792458 m/s.
He isn't asking what the numerical value of the speed of light is.
He's asking what the velocities of two photons would be if they are going in opposite directions.
Here a third observer is necessary. A third observer will see the speed of both photons as +c and -c respectively.
The photons and indeed all massless particles HAVE NO REFERENCE POINT. That is to say, there is no meaning in asking what the photons will measure as. It does not violate velocity addition because photons do not actually have a frame of reference. You cannot take a photon as a point of reference either since it is always going at c - this violates energy conservation. Suppose you are in one universe with you and a photon; the photon is moving at velocity c towards you. Change your reference point such that YOU are going at c towards a stationary photon - and you have infinite KE from the POV of the photon, which is of course, absurd (or is it!?) according to SR's kinetic energy/mass equation. And that also removes the concept of any absolute reference point for the universe. It's strange that these are intricately linked but I guess that's the way it is.
Shut up and calculate, as they say.
What regulates the speed of light in space? Near a black hole does light slow down, speed up, change directions, or something else?
It appears to slow down to us but it's actually "changing directions" from what I gather. More specifically, it's following the path of least time which will obviously be in a straight line - the black hole curves the "straight path" but it's still the path of least time.
Is there a 'media' which light travels? If there is, is it manipulated by gravity?
Well [tex]c^2={\epsilon_0\mu_0}[/tex] where the two parameters are the permittivity and permeability of "free space" - in other words, how well empty space responds to propagating electric/magnetic fields.
Thanks dst, and everyone else for your time. I can imagine this questions pops up quite often! Thanks again!
relative speed
Rather than discuss photons, which have no meaningful reference frame, let's shoot particles (with non-zero mass) in opposite directions at 0.99c with respect to the earth. Using the relativistic addition of velocity formula, the relative speed of one with respect to the other would be about 0.99995 c, still less than the speed of light.
Of course, according to someone on Earth the particles separate at almost twice the speed of light. But that's not their speed relative to each other. (Rindler uses the term mutual velocity for this separation rate.)
Careful, he asked what would the velocities be relative to each other and furthermore he did not say photons but mentioned particles.
Careful, that was not the Michelson-Morley experiment you are referring to but an experiment to measure the speed of light.
Pray tell what "speed of light particles" are if not "photons"? :rolleyes: (don't be a smartass and say gluon, graviton or any other type)
I'm pretty sure the OP knows that you can't have mass-ful particles going at the speed of light so by deduction that leaves one possibility.
Let's keep with the original point,(as I see it), we are given two particles going at the speed of light, will they be going greater than c relative to each other? answer is "no". As doc al seems to satisfy you in the process of keeping with the overall point, suppose then the particles are going at .99c then the result would be similar. The relative velocity would not be greater than c. Again noting, that is the point of Einstein's theory of special relativity.
  • · Replies 19 ·
  • · Replies 50 ·
  • · Replies 40 ·
17K
  • · Replies 93 ·
  • · Replies 26 ·
