Voltage Source with output of OV
The discussion centers on the behavior of voltage sources, specifically addressing whether a voltage source turned off is equivalent to one outputting 0V. It is established that an ideal voltage source at 0V acts as a short circuit, while a powered-down voltage source does not necessarily behave as a short due to its internal components. When connecting a voltage source to an energized DC network with matching voltage, no current flows, indicating that the source does not influence the circuit under those conditions. The superposition theorem is also referenced, highlighting the treatment of voltage sources in circuit analysis.
  • Understanding of voltage sources and their characteristics
  • Knowledge of circuit theory, particularly the superposition theorem
  • Familiarity with DC networks and potential differences
  • Basic electronics concepts, including short circuits and open circuits
  • Study the characteristics of ideal vs. real voltage sources
  • Learn about the superposition theorem in circuit analysis
  • Explore the internal components of voltage sources and their effects on circuit behavior
  • Investigate the implications of connecting voltage sources to energized networks
Electrical engineers, electronics students, and anyone interested in understanding the principles of voltage sources and circuit behavior in DC networks.
flexifirm
My friend asked me a question that totally shocked me for a second.. here was the question...
"Is a voltage source turned off the same as a voltage source outputting 0V or near 0V?"
Then he asked me if we connected the two terminals of a voltage source to two points on an already ENERGIZED dc network... and the voltage output of the voltage source matches the exact same voltage that was in the network between the two points.. what is the effect? What is the effect when we change the voltage source (variable) to an output of 0.000001V and plug it between those two points? WHat is the effect of turning off the voltage source and plugging it between those two points?
My take on it is... a voltage source turned on but outputting 0V should be considered a short, but turned off should be considered an open (I'm thinking back to a simple power supply with a bridge rectifier a cap and a zener... u have the bridge to provide the open - yet in one direction current can go in one terminal of the power supply... through a set of diodes and come out the other end of the supply).
Also, when using the superposition theorem.. we TURN OFF the sources... and we replace an ideal voltage source with a short...
Any thoughts on what my inquisitive friend was blabbering about?
A voltage source does not "output" a voltage -- it maintains a voltage between its terminals by sourcing current, if necessary. An "ideal" voltage source set for 0V would indeed act as a short. A real voltage source, however, is quite complicated inside, with transistors and capacitors and other internal components; turning it off probably won't make it into a short.
If you connect a 5V source to two wires already having a potential difference of 5V, nothing "happens," in the sense that no current flows.
- Warren
If your voltage source is powered down, then the output might not be shorted.
Regards
