| Thread Closed |
Bernoulli Principle Problem |
Share Thread |
| Apr12-08, 09:54 PM | #1 |
Find the lift in newtons due to the Bernoulli Principle on a wing of a plane of area 84.5 m^2 if the air passes over the top and the bottom surfaces at speeds of 347m/s and 289 m/s 2. Relevant equations P1+(1/2)densityV^2 =P2+(1/2)densityV^2 3. The attempt at a solution Ok so i know the density of air is 1.29kg/m^3 so i plug into equation to get 1/2(1.29kg/m^3)(347m/s)^2= 1/2(1.29kg/m^3)(289m/s)^2 then i get answer of 5.39x10^4 N/m^2 then i use equation F=PA and P is 5.39x10^4 N/m^2 and A is 84.5m^2 to get answer of 4.6x10^6 N Am i correct ? |
| Apr13-08, 12:51 AM | #2 |
By bernouili equation
Pa+1/2pva^2 = Pb =1/2pvb^2 1/2pvb^2-1/2pva^2 =Pa-Pb deltaP = 1/2pvb^2-1/2pva^2 deltaP * A =Lift force I think your method is correct |
| Thread Closed |
Similar discussions for: Bernoulli Principle Problem
| ----bernoulli principle in fan---- | Mechanical Engineering | 8 | ||
| Bernoulli Problem | Introductory Physics Homework | 4 | ||
| Differential Equations - Bernoulli Problem | Calculus & Beyond Homework | 1 | ||
| A-Level Investigation into Bernoulli Principle | General Physics | 0 | ||
| Bernoulli Principle | General Physics | 1 | ||
