Thread Closed
Newton's Rings
Share Thread
Apr13-08, 12:12 AM   #1
Newton's Rings
In a Newton's Rings experiment, involving a curved lens on a glass surface, what might have happened to the set-up to see a bright spot at the centre?
2. The attempt at a solution
Well I know that normally we get a dark spot at the centre because of the lambda/2 phase difference which causes destructive interference, but I am a little confused with how a bright spot could be seen at the centre.
My first thought was that perhaps an air gap was left between the centre of the lens and the glass but i'm not really sure.
cheers
Steven
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Apr13-08, 03:55 AM   #2
Anyone got any suggestions?
i was thinking it must have something to do with the phase differences on exit, but no idea how to relate this to the experiment.
btw: here is a link
http://physics.bu.edu/~duffy/semeste...ons_rings.html
I know that the equation for the radius of the m'th Newton's bright ring is:
[tex]x_m = \left[ {\left( {m + \frac{1}{2}} \right)\lambda R} \right]^{1/2} [/tex]
where:
R is the radius of curvature of the lens the light is passing through,
m is 0,1,2,3... which is dependent upon the number of light spots,
λ is the wavelength of the light passing through the glass.
Apr13-08, 06:12 AM   #3
nevermind I found the solution elsewhere.
Turns out it is because of the air gap between the lens and the glass.
Upon reflection, there is a further phase difference, meaning that it will be > lambda/2
and hence not give fully destructive interference and give a bright spot.
thanks neways
Apr13-08, 07:39 AM   #4
Newton's Rings
anyway, you can change the result of Newton ring.
Just view at the bottom of the ring. the transmission of light should be opposite to the surface
Thread Closed
Similar discussions for: Newton's Rings
Thread Forum Replies
Newton's Rings Introductory Physics Homework 1
Newton's Rings (Fringes) Introductory Physics Homework 3
Newton's Rings. General Physics 0
Newton's Rings Help Introductory Physics Homework 2
