Help understanding nuclear property
  • Context: Graduate
  • Thread starter Thread starter Sean Reed
    Nuclear Property
The discussion revolves around the interpretation of Full Width at Half Maximum (FWHM) in gamma decay measurements using a germanium gamma ray detector. Participants explore the relationship between FWHM, energy measurements, and the characteristics of decay sources, including variations in FWHM for different samples of Am-241.
  • One participant notes that the FWHM of the gamma decay curve is influenced by noise in the equipment and seeks to understand its significance regarding the source itself.
  • Another participant explains that the FWHM is related to the number of particle-hole pairs in the detector and suggests that it is proportional to the square root of energy.
  • A participant questions whether the FWHM serves as a measure of the energy of the decay, receiving a mixed affirmation.
  • One participant introduces the Breit-Wigner cross-section formula, indicating that the FWHM is related to the decay rate and probability of decay.
  • A participant inquires about the differing FWHM values for two Am-241 samples, noting that the stronger sample yields a smaller FWHM.
  • Another participant mentions that the intrinsic width of resonances and the intensity of detected alphas may affect the FWHM.
Participants express varying interpretations of the significance of FWHM, with some suggesting it relates to energy measurements while others clarify that it is more complex, involving decay rates and detector resolution. The discussion remains unresolved regarding the precise implications of FWHM in different contexts.
Participants reference various factors that may influence FWHM, including detector resolution, intensity of decay events, and intrinsic properties of the decay sources. The discussion highlights the complexity of measuring and interpreting FWHM in relation to gamma decay.
Sean Reed
Using a small germanium gamma ray detector I have been collecting data on some newly acquired gamma decay sources. The program I have been using gives me a plot of counts vs energy (well channel, but the channels are proportional to the energy) Thus after collecting data I have a bell shaped curve with the peak centered near or on the energy of the decay I am looking at. What I am confused on is what importance in this does the FWHM have with regards to the source its self? I know some of the cause of the curve is noise in the equipment, but what meaning does it have with the source.
I feel like there is some meaning the FWHM has about the source because I used a large detector to measure the decays per second of the source, then I had to switch to a small detector and when I did I only looked at the FWHM of the curves.
Any help is greatly appreciated
You distribution is gaussian (since you have collected much data),
FWHM = [itex]\Delta E = 2.35\sigma[/itex]
http://mathworld.wolfram.com/GaussianFunction.html
sigma is related to the number of electrons causing the signal (particle-hole paris in the Ge-detector), hence the higher energy the more particle-hole paris. So the FWHM is proportional to E^(½) since [itex]\sigma = \sqrt{\bar{n}}[/itex].
Now take the ratio FWHM/E, we see that the ratio (the resolution if you like) is poportional to E^(-½).
So the width is also a measurment of the gamma-ray energy.
So am I correct that the importance of the FWHM is that it is another way to measure the energy of the decay?
sort of yes
"So am I correct that the importance of the FWHM is that it is another way to measure the energy of the decay?"
Not quite.
I assume you are talking about the photon energies?
A relavent formula here is the Briet Wigner Cross section:
[tex]\sigma^{2}=\frac{1}{(E-E_{0})^{2}+\Gamma^{2}/4}[/tex]
ie. the probability of decaying from |E> to |E0>, where [tex]\Gamma[/tex] is the decay rate (cos of Heisenberg uncertainty relation), expressed in units of energy. Ofcourse, the count rate is proportional to the probability.
By inspection, you can see that the FWHM is equal to [tex]\Gamma[/tex] (prob falls to half height when [tex]\(E=E_{0}+or-\Gamma/2[/tex]
So when I am using the detector for the alpha particles of Am-241 samples, why will they have different FWHM values? Specifically I have two samples of Am-241 and the stronger sample (more Ci) always gives me a smaller FWHM.
thanks
vertices: that is the intrinsic width of resonances.
Now we where discussing the detector resolution.
Sean_Reed:
Yes, since you will also get a higher peak (more registered alphas) due to higher intensity of alphas, the FWHM will go down. There are many parameters that governs the FWHM. What textbook do you use for this laboration?
12K
  • · Replies 19 ·
