| Thread Closed |
sliding and toppling. |
Share Thread | Thread Tools |
| Apr27-04, 03:49 PM | #1 |
Ok, I have a maths question. This is a little different because I dont want the answer, I want the formula so I can work out the answer (and future answers) myself. lol it's not very good self-learning with a book that doesnt tell you much. Anyway here is the question.
A solid uniform cube of side 4cm and weight 60N is situated on a rough horizontal plane. The coefficient of friction between the cube and the plane is 0.4. A force, P, acts in the middle of one of the edges of the top of the cube, at right angles to it and at angle theta to the upward vertical. In the cses when the value theta is (a) 60 degrees (b) 80 degrees, find (i) the force P needed to make the cube slide, assuming it does not topple; (ii) the force P needed to make the cube topple, assuming it does not slide. So I have tried many variations using sin, cos and tan but cannot seem to get the right answer. Can someone tell me the formula so i can work these out for myself? |
| Apr28-04, 07:44 PM | #2 |
Mentor
Don't think in terms of finding "the formula". Instead, learn the basic physics involved and then you can figure out all the formulas you need no matter what.
As always in these kinds of problems, consider all the forces acting on the object. I count four: (1) the applied force P, which acts along the angle you described (θ from vertical), (2) the weight of the cube, (3) the friction of the plane against the cube, and (4) the normal force of the plane up on the cube. Draw a picture! The sum of the forces in the y-direction must equal zero, so: P cosθ -mg + N = 0 The sum of the forces in the x-direction must also equal zero, so: P sinθ -μN = 0 Use these equations to figure out P, given θ. mgL/2 - P cosθ(L/2) - P sinθL = 0 ("L" is the length of the side of the cube.) I'll leave it for you to figure out what I did to get that equation.
| Thread Closed |
| Thread Tools | |
Similar Threads for: sliding and toppling.
| sliding ice | Introductory Physics Homework | 4 | ||
| sliding block | Introductory Physics Homework | 3 | ||
| another sliding question | Introductory Physics Homework | 1 | ||
| Sliding down a pole | Advanced Physics Homework | 7 | ||
| the Toppling of a transmitter mast | Introductory Physics Homework | 6 | ||
