How Does a Vertical Spring's Force Affect Oscillation and Position Calculations?
The discussion revolves around a vertical spring system subjected to a force, exploring concepts related to oscillation periods, positions during motion, and spring forces at various displacements. The problem involves calculations of mass, oscillation period, and forces exerted by the spring at specific positions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of mass required for a specific oscillation period and the position of the object at a given time after passing the equilibrium position. There are attempts to apply various equations related to oscillatory motion, with some participants questioning the correctness of their approaches and the assumptions made regarding phase constants.
Several participants are actively engaging with the problem, providing different attempts and questioning the validity of their methods. Some guidance has been offered regarding the use of phase constants in the equations, and there is an exploration of the implications of using different mathematical forms for the oscillation equations.
Participants note potential misunderstandings regarding the behavior of the spring at equilibrium and the forces acting on the object, indicating a need for clarity on the definitions and assumptions used in their calculations.
clope023
A force of magnitude 39.5N stretches a vertical spring a distance 0.256m.
a) What mass must be suspended from the spring so that the system will oscillate with a period of 1.10s?
got 4.73kg
b) If the amplitude of the motion is 5.00×10−2m and the period is that specified in part (a), where is the object at a time 0.320s after it has passed the equilibrium position, moving downward? (Take the upward direction positive.)
c) What force (magnitude) does the spring exert on the object when it is a distance 2.50×10−2m below the equilibrium position, moving upward?
d) direction of part c's force?
T = 2pi/omega
omega = 2pi/T
x = Acos(omegat+phi)
F = kx
F/x = k = 154.3N
T = 2pi(m/k)^1/2
b) x = Acos((2pi/1.10)*.320) = .04998 ~ .05m - incorrect
c) 1. F = kx = (154.3)(2.5x10^-2) = 3.9 - incorrect
2. F = k[tex]\int[/tex]xdx (from 5x10^-2 to 2.5x10^-2)
= -.1446m - incorrect
I don't know why the equations aren't working for me, any help is appreciated.
I believe it has something to do with the period after the equilibrium position, but am not sure.
another attempts at getting part b)
kx = -bv
kx = -2(km)^1/2(omegaA)
x = (-2(km)^1/2(omegaA))/k = -.100
didn't want to plug it into masteringphysics since I have only one try left, is this correct? (or am I getting warmer?)
another attempts
x = Ae^((-b/2m)t)cos(omega't+phi)
omega' = (k/m-b^2/4m^2) = (k/m-k/m) = 0
cos(0) = 1
x = Ae^((-2(km)^1/2/2m).320)(1) = .0080
not sure about this one since this is for damped oscillations?
Hi clope023,
I believe your attempt at part b in the original post was close. However, if you'll notice that the equation you use does not match the equation you list in your relevant equations section; it's missing the phase constant phi.
To see what's happening, with your equation, you're using
x = A cos( omega t)
We want the object at t=0 to be at the equilibrium position, but at t=0 the equation you used indicates that object is at x=A. (So it looks like what you found was the position of the object 0.32 seconds after the object reached the highest point.)
To match the functional forms with the behavior at t=0, there are 4 special cases that are good to know:
x=A cos(omega t) : at t=0, object is at x=A
x=-A cos(omega t) : at t=0, object is at x=-A
x=A sin(omega t) : at t=0, object is at equilibrium position (x=0) and moving towards positive x
x=-A sin(omega t) : at t=0 object is at equilibrium position (x=0) and moving towards negative x
(These ideas come from looking at plots of all four functions.) If it's not one of those special cases you'll need to use a function with a phase shift phi that gives the function the proper behavior with time.
About part c: What if they had asked for the force that the spring exerts on the object when the object is at the equilibrium position? We are using x=0 to be the equilibrium position, but the spring force there is not zero.
part b:
if using x = A cos(omega*t), we must first determine when it has passed the equilibrium position, moving downward.
x = A cos(omega*t) = 0
dx/dt = -A*omega sin(omega*t) < 0
so omega*t = pi/2
then we want to find x = A cos(omega*(t + 0.320)) = A cos(pi/2 + omega*0.320) = -A sin(omega*0.320)
part c: when it is a distance 2.50×10−2m below the equilibrium position (no matter moving upward of downward), x = -2.50×10−2m
But f = kx is NOT the force F exerted by spring, it is the net force. 2 forces act on the object. At x = -2.50×10−2m, the amount of stretch of spring is x1 + x, where kx1 = mg, so the required force is k(x1 + x) = mg + kx, with upward direction.
