2 AP Test questions I can't solve
  • Context: Undergrad
  • Thread starter Thread starter nivek114
    Ap Test
This discussion focuses on two AP Calculus problems involving the functions f(x) = e^x and g(x) = ln(x), as well as the volume of a hot air balloon modeled by a function r(t). The first problem requires finding the area between the curves of f and g from x = 1/2 to x = 1, calculating the volume generated by revolving this area around the line y = 4, and determining the absolute extrema of the function h(x) = f(x) - g(x) on the same interval. The second problem involves analyzing the rate of change of the balloon's volume and approximating the integral of the rate of change over time using a right Riemann sum.
  • Understanding of definite integrals and area between curves
  • Knowledge of volume of revolution concepts
  • Familiarity with Riemann sums and their applications
  • Basic calculus concepts including derivatives and extrema
  • Study the method for calculating areas between curves using definite integrals
  • Learn about the volume of solids of revolution using the disk and washer methods
  • Review Riemann sums and their application in approximating integrals
  • Explore the concepts of concavity and its implications on function behavior
Students preparing for the AP Calculus exam, educators teaching calculus concepts, and anyone seeking to improve their understanding of integration and volume calculations in calculus.
nivek114
Hi, the AP test is approaching and I'm struggling with these two Calculus questions and need some guidance. If you can provide a general (or detailed if possible =)) explanation on how you solved the problem, or the strategy you used for the problem, I would be extremely grateful. Solving even just one part will help me immensely! So here goes...
1. Let f and g be the functions given by f(x)=e^x and g(x) = ln(x)
a. Find the area of the region enclosed by the graphs of f and g between x = 1/2 and x=1.
b. Find the volume of the solid generated when the region enclosed by the graphs of f and g between x= 1/2 and x=1 is revolved around the line y=4.
c. Let h be the function given by h(x) = f(x) - g(x). Find the absolute minimum value of h(x) on the closed interval [1/2,1] and find the absolute maximum value of h(x) on the closed interval [1/2,1].
2.
t(minutes) 0 2 5 7 11 12
r ' (t) (feet/min) 5.7 4.0 2.0 1.2 0.6 0.5 (Note: this is a table)
The volume of a spherical hot air balloon expands as the air inside the balloon is heated. The radius of the balloon, in feet, is modeled by a twice-differentiable function r of time t, where t is measured in minutes. For 0<t<12, the graph of r is concave down. The table above gives seleceted values of the rate of change, r ' (t), of the radius of the balloon over the time interval [0,12]. The radius of the balloon is 30 feet when t = 5. (Note: The volume of a sphere of radius r is given by V = 4/3(pi)(r^3).
a. Find the rate of change of the volume of the balloon with respect to time when t=5. Indicate units of measure.
b. Use a right reimann sum with the five subintervals indicated by the data in the table to approximate the integral(antidifferentiation) from 0 to 12 of r ' (t) dt.
c. Using the correct units, explain the meaning of your solution from part b in terms of the radius of the balloon.
So there it is...any help is appreciated, good luck, and thanks in advance :X
do you have no idea where to start? if you know what concepts this deals with but are having trouble filling in the gaps do this:
draw a picture for both problems. for the first plot the functions, their intersections y=4 etc. for the second plot the points and then draw the riemann rectangles.
  • · Replies 20 ·
