Discrete spacetime means discrete momentum ?
The discussion centers on the implications of discrete spacetime on momentum, specifically referencing De Broglie's wavelength formula, \(\lambda = h|p|^{-1}\). It concludes that if spacetime is discrete, it implies a minimum wavelength, potentially equal to the Planck length, leading to a maximum allowed momentum. This framework suggests that finite momentum and spacetime could eliminate infrared (IR) and ultraviolet (UV) divergences in quantum field theories. However, the complexity of general relativity (GR) indicates that treating spacetime as a quantum system may complicate the notion of discretization.
  • Understanding of De Broglie's wavelength and momentum relationship
  • Familiarity with Planck length and its significance in physics
  • Basic knowledge of quantum field theory and divergences
  • Concepts of lattice models in high energy physics and condensed matter
  • Explore the implications of discrete spacetime in quantum gravity theories
  • Study the role of lattice models in quantum field theory calculations
  • Investigate the relationship between Planck length and quantum mechanics
  • Learn about general relativity's treatment of spacetime and quantum superposition
Physicists, particularly those specializing in quantum mechanics, quantum field theory, and general relativity, as well as researchers interested in the foundations of spacetime and momentum in theoretical physics.
mhill
discrete spacetime means discrete momentum ??
the question is using De Broglie's Wavelength [tex]\lambda = h|p|^{-1}[/tex]
then in case space is discrete would mean that there is a minimum possible wavelength in nature , for example [tex]\lambda = k l_{p}[/tex] for Planck's length this would mean that the maximum allowed momentum modulus would be [tex]h(k l_{p})^{-1}[/tex] for 'k' a constant , then since momentum is finite and spacetime is also finite there wouldn't be any IR or UV divergences but does this make sense
Yes. Lattice models are often used in calculations for high energy physics or in condensed matter when considering lattices. However, note that discrete spacetime may not be that simple --- if we take GR seriously and treat the spacetime as part of the system, it will be in a quantum superposition of states, and it may not be necessarily the case that physical properties are still as manifestly discretised.
  • · Replies 36 ·
