How Do I Make a Balloon Pop by Itself?
  • Thread starter Thread starter Cory-O
    Balloon
The discussion revolves around methods to make a balloon pop by itself without the knowledge of the person holding it. Participants explore various theoretical and practical approaches, including chemical reactions, physical manipulation, and environmental conditions.
  • Some participants suggest using heat, such as a medium power laser, to pop the balloon.
  • Others propose combining slow-acting chemicals that create overpressure as a method.
  • Dry ice is mentioned as a potential option, though concerns about its introduction without notice are raised.
  • One participant humorously suggests using small pointy objects or fire, but acknowledges the difficulty of implementation without detection.
  • A method involving a tiny electric match and RF receiver is proposed as a discreet option.
  • Another suggestion involves excessively charging the balloon and having the person stand on a negatively charged surface to create a zap upon contact.
  • A detailed technique is shared involving tape and a small cut in the balloon to create tension that leads to popping.
  • Some participants express caution regarding the use of lasers and solvents, emphasizing safety concerns.
  • One participant humorously suggests using a slingshot as a method.
  • A method involving filling the balloon in a cold environment and then bringing it into a hot room is also discussed.
  • Another idea involves using a strong magnet and iron filings, though its feasibility is not elaborated upon.
Participants present multiple competing views and methods, with no consensus reached on the best approach to achieve the goal. The discussion remains unresolved with various ideas and techniques proposed.
Some methods discussed rely on specific conditions or materials that may not be readily available, and the effectiveness of certain approaches is uncertain. Safety concerns are also noted regarding the use of lasers and chemicals.
Individuals interested in practical physics applications, experimental methods, or creative problem-solving may find the discussion relevant.
Cory-O
Hi,
I'm trying to find a way to make a balloon pop by itself in somebody's hands without them seeing how it happened. What's the best way to do this?
Thanks,
-Cory
Welcome to PF, Cory.
There are a few ways, but they're all kind of elaborate. The easiest way would be to heat it somehow. If it isn't totally transparent, a medium power laser could do that.
Otherwise, you could combine a couple of slow-acting chemicals that will react and produce an overpressure.
Personally, I'd just take a spit-ball to the thing.
Dry ice might work ?
Possibly. It might be hard to seruptitiously introduce in sufficient quantity, though.
glue small pointy objects to his/her palms lol.
fire
Those are both decent ideas, but I can't see how they can be implemented without the 'victim' noticing.
Put a hole in it before you blow it up.
So then, how do you blow it up?
A tiny electric match + RF reciever inside, let it trigger as necessary.
Yeah, I'd forgotten how small radio receivers can be these days. That's a good option.
Positively charge the balloon 'excessively', and make sure the "victim" is standing barefoot on a surface that's 'excessively' negatively charged. When the balloon and victim make contact...ZAP!
You may need to know CPR...
blow the balloon up, stick a small piece of tape to the balloon about 5-10mm, deflate the balloon then turn it inside out and make a small cut in the balloon behind the tape without cutting the tape, blow the balloon up again slightly larger than before and after a few seconds the extra tension in the balloon will overcome the tape and the balloon will burst. A small amount of solvent may speed things up if it takes to long.
:smile:
The easiest way of course, is just a mixture of chemicals as already suggested.
Hmmmm good question you could use a sling shot I guess :rolleyes:
BAD BAD BAD! Never point a laser in the direction of anybody!
I would just use some kind of solvent on the inside of the balloon that will weaken the latex and cause it to break after a while.
Be sneaky like Houdini.
Develop a thick callus on your palm in one spot, rough up the surface a little, take a very small pinch of ground glass and mix with Elmer's glue. Apply to callus, in an amount equal ~ 1/3 of a grain of rice ( Tres Fino Arborio, preferably ).
I usually tend to go for the simple method.
Fill it up in a very cold environment with very cold cold gas, bring it into hot room and if you've weakened the latex it'll pop
Yeah, if money is no object, an infrared laser pulse. Get a special balloon that really absorbs the particular frequency of the laser. That way, if you miss, you don't drill a hole in somebody's hand or something.
What about a very strong magnet and some iron filings
  • · Replies 29 ·
