Thread Closed
Tutorial: Vectors
Share Thread
Apr17-08, 01:33 PM   #1
Tutorial: Vectors
Tutorial: Vectors
About the Tutorial
I see a lot of questions related to vectors on these forums, so I thought it would be a good idea to post a Tutorial on how to solve some of the easier questions related to Vectors. This Guide is quite long but should cover the basics.
How will this thread work?
I will post a short tutorial on a particular sub-topic on vectors, this will then be followed by a few question and answers. This thread has been made as an introduction to people who are new to vectors and to people who want to touch up on them.
What you will need
  • A Basic Calculator.
  • Some knowledge of both Pythagoras' Theorem and Trigonometry.
  • Patience!
NOTE: With vectors there is sometimes the option of a scale drawing; this tutorial does that cover that. I believe that by using the method I am about to show if probably the most flexible in terms of solving a problem, though in some cases a scale drawing may be necessary.
_Mayday_
Please contact me via PM if you feel there is anything that may enhance the quality, or make it more user friendly.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Apr17-08, 01:35 PM   #2
UNIT 1
Part 1: Vector Quantities
Vectors are quantities that have both magnitude and direction. Examples of vectors include Force, Acceleration and Velocity. When adding vectors you need to take their direction into account. When adding vectors that are on the same plain it is just a question of addition and subtraction as shown below. If two vectors are acting in the same direction, then they can be added together, and if they are acting in opposite direction one can be subtracted from the other.
Acting in the same direction
Acting in opposite directions
Adding Forces at right angles
When two vectors are acting at right angles to each other, you can apply Pythagoras' theorem. Below I will take you through an example, please not this will only apply to forces arranged at right angles.
In the first image you see two forces being applied on an object. It is important to include arrows which show in which direction the force is being acted in. I will take you through this and then leave you a few questions in later posts, note that the answers will be under the question in white to see it simply highlight it.
1. Firstly you need to arrange the arrows in order, in other words in vectors you can arrange them so that all the forces lead on from on another. So in this case you can move the 4.0 N to the right so that it follows on from the 3.0 N, not that the angle between them will still be a right angle, and this helps you determine the direction of the resultant force. The resultant force is from the point at which you start the vector to the point at which it ends in a straight line, as long as the other vectors follow on. Like this:
As you can see (a) and (b) follow on from each other, and (c) the resultant goes from he beginning to the end in a straight line.
2. Now you can apply your knowledge of Pythagoras' theorem. So, this is how I would do it:
[itex]a^2 + b^2 = c^2[/itex]
[itex]4^2 + 3^2 = c^2[/itex]
[itex]16 + 9 = c^2 (25)[/itex]
Remember now that you have [itex]c^2[/itex] you need to root it to get the resultant, do not forget this bit!
[itex]\sqrt{25} = 5.0 N[/itex]
Now if you have made the forces follow on from each other then the hypotenuse is acting in the same direction as the resultant force.
Understand? If so then why not try some of the questions posted below?
Part 2: Using Trigonometry
If you know your trig, this shouldn't be too difficult. If you are unsure I have provided a link to the level of trg you need.
Sometimes it is necessary to split vectors into Horizontal and Vertical components. This is important for example when you only have one angle and one force like the example below:
At first, to some this may look impossible. I will take you through this one, and then set a few questions that you can try yourself.
1. Write down what you have in terms of information. You have an angle, and you have the hypoteneus. Now you need to think which of sin, cos or tan fit this. In this case it will be sine, as you are looking for the opposite (or verticle)
2.Now arrange it into an equation similar to this:
[itex]\sin(45) = \frac{vertical}{12.0 N}[/itex]
Now you can rearrange it to:
[itex]\sin(45) \times 12.0 N = Vertical (8.5 N)[/itex]
3. Now you can do this next bit two ways. One way would be to use Pythagoras' theorum as you now have two sides of a right angle triangle. I would do it in a similar way to 2. as if you have made a mistake in finding the vertical component, you can still get this right.
4. Again, find out which of sin, cos or tan you will need to use. Now you are looking for the adjacent, so we will use cos.
5. This is how I would do it:
[itex]\cos(45) = \frac{Adjacent}{12.0 N}[/itex]
Rearrange to:
[itex]\cos(45) \times 12.0 N = Adjacent (8.5 N)[/itex]
Apr17-08, 01:36 PM   #3
Questions: Set 1
Q1. Calculate the magnitude of the resultant force of these vectors
a)
b)
c)
Q2. A speed boat is directed due north at [itex]240ms^{-1}[/itex]. A side current is acting on the boat due west at [itex]53ms^{-1}[/itex]. Find the resultant force and the direction in which the force is directed?
Q3. A football is rolled on a flat table due north at [itex]5ms^{-1}[/itex]. A side wind acts on the football due east at [itex]2ms^{-1}[/itex]. Calculate the resultant force and the direction in which the force is directed?
Apr17-08, 01:36 PM   #4
Tutorial: Vectors
Answers: Set 1
Q1. These are just a case of using [itex]a^2+b^2=c^2[/itex]
a) [itex]5^2 + 10^2 = 125[/itex]
[itex]25 + 100 = 125[/itex]
[itex]\sqrt{125} = 11.2 N[/itex]
NOTE: The answer of 125 is [itex]c^2[/itex] so you need to root your answer to get the resultant.
b) [itex]6^2 + 17^2 = 325[/itex]
[itex]36 + 289 = 325[/itex]
[itex]\sqrt{325} = 18.0 N[/itex]
c) [itex]110^2 + 250^2 = 74600[/itex]
[itex]12100 + 62500 = 74600[/itex]
[itex]\sqrt{74600} = 273 N[/itex]
Q2. For the next 2 questions, as I advised a small sketch similar to ones int he previous question can help!
a) [itex]240^2 + 53^2 = 60409[/itex]
[itex]57600 + 2809 = 60409[/itex]
[itex]\sqrt{60409} = 245.7 N[/itex]
[itex]12.6 Degrees[/itex]
Q3.
a) [itex]5^2 + 2^2 = 29[/itex]
[itex]25 + 4 = 29[/itex]
[itex]\sqrt{29} = 5.4 N[/itex]
[itex]21.8 Degrees[/itex]
Thread Closed
Similar discussions for: Tutorial: Vectors
Thread Forum Replies
CFD tutorial Mechanical Engineering 4
C# Tutorial Programming & Comp Sci 13
Position Vectors, Velocity Vectors, and Acceleration Vectors Introductory Physics Homework 3
GR Tutorial Special & General Relativity 2
PROOF: Independent vectors and spanning vectors Linear & Abstract Algebra 8
