Okay, here is my hypothetical situation. Lets say there is a cylinder
  • Context: Undergrad
  • Thread starter Thread starter jehubuddaka
    Cylinder Hypothetical
The discussion centers on the physics of a cylinder with a diameter of 48 inches and two rods, each capable of sliding 1 inch horizontally. The first rod extends to the right and touches the floor when the cylinder is rolled clockwise. The user seeks to determine if the force from the second rod, also extended to the right, can generate enough torque to roll the cylinder further until the rod becomes vertical. The conclusion drawn is that the point of contact with the floor remains stationary while the rod tips, and the necessary calculations involve torque and angles to predict the direction of the fall of the X-shaped configuration formed by the rods.
  • Understanding of basic physics concepts, specifically torque and rotational force.
  • Familiarity with the principles of levers and fulcrums.
  • Knowledge of angular motion and its calculations.
  • Ability to visualize three-dimensional objects and their movements.
  • Study the principles of torque and how it affects rotational motion.
  • Learn about the calculations involved in determining the angle of inclination and its effects on stability.
  • Explore the mechanics of levers, including the conditions for equilibrium and motion.
  • Investigate real-world applications of these principles in engineering and physics problems.
Students of physics, engineers, and anyone interested in understanding the mechanics of rotational forces and torque in practical scenarios.
jehubuddaka
Okay, here is my hypothetical situation. Let's say there is a cylinder and we're looking at it with the round side facing us. Its diameter is 48in. There is a 48in rod going through that cylinder(with the ends shaped so that it conforms to the circumference of the cylinder) from the left side to the right side perfectly in parallel with the floor, which is level. Now imagine that rod can slide to the left and right 1 inch. Still following? OK, next roll that cylinder clockwise until the rod, which is now extended its full 1 inch to the right, touches the floor. Now imagine a second rod going through that cylinder exactly the same as the first, parallel to the floor and extended to the right 1 inch. would it have the required rotational force to roll the cylinder the rest of the way clockwise until the rod was vertical?
My thought is the only force required is enough to take the rod touching the floor, and tilt it to the right the few degrees required with the fulcrum being the point where it is touching the floor. Am I right that the point touching the floor would remain pretty much stationary while the rod tipped?
I wish I had one more physics class, this doesn't seem like that hard of a question to me, but I just don't know the formulas required.
Ignore the cylinder. Say you made a X out of the two rods, one is the near vertical one on the floor, the other is the horizontal one offset to the right, with the same constraints of 1 inch of movement. At some near veritical angle, the X will fall to the right instead of the left. So you just need to calculate the angle the near vertical rod is at, and then the torque forces on the X to see which way it would fall.
lol now that you put it that way, it's kinda easy. thanks.
  • · Replies 20 ·
  • · Replies 31 ·
  • · Replies 52 ·
9K
  • · Replies 27 ·
