Can the Infinite Monkey Theorem Predict Pi's Digits in Phi's Expansion?
  • Context: Graduate
  • Thread starter Thread starter Diffy
    Infinite Phi Pi
The discussion centers on the application of the Infinite Monkey Theorem to the decimal expansions of the irrational numbers pi (π) and phi (φ). Participants explore whether the digits of π would appear within the decimal expansion of φ and vice versa, considering the implications of normality in numbers.
  • Some participants propose that since both π and φ are irrational, the digits in their decimal expansions are essentially random, suggesting that the first billion digits of π would almost certainly appear in φ.
  • Others argue that this assumption does not hold without the numbers being normal, pointing out that not all irrational numbers exhibit this property.
  • A participant mentions a specific irrational number that does not contain certain digits, challenging the idea that all irrational numbers have random digit distributions.
  • There is a conjecture that if π is 10-normal, it would contain the initial k digits of φ infinitely many times, and vice versa.
  • Some participants express uncertainty about the normality of π and φ, noting that it is not proven whether they are normal numbers.
  • Speculation arises that if π and φ are indeed normal, they would conform to the Infinite Monkey Theorem, allowing for the appearance of any digit string.
  • One participant highlights the distinction between events with probability 1 and certainty, emphasizing that while a random real number is likely to be irrational, this does not guarantee that all properties of normality apply.
Participants generally do not agree on the implications of the Infinite Monkey Theorem as it relates to π and φ, with multiple competing views on the necessity of normality for the theorem to apply. The discussion remains unresolved regarding the normality of these numbers and its implications.
The discussion reflects limitations in the understanding of normality and its implications for irrational numbers, as well as the dependence on conjectures that are not universally accepted or proven.
Diffy
I guess one could use any irrational numbers here, but phi and pi are favorites.
I am sure that most people are aware of the infinite monkey theorem. If not use http://en.wikipedia.org/wiki/Infinite_monkey_theorem as a reference.
By using this theorem, could one say that the the first billion decimal digits of pi (in order) almost certainly would show up somewhere in the decimal digits of phi? Of course where this phenomenon would occur would start at some unimaginably enormous number.
I assume this would be true. Since phi is irrational, the digits in its decimal expansion have no pattern, so essentially they are random.
To take this one step further, could one say that the said pattern of the first billion digits of pi, would occur within the decimal expansion of phi an infinite number of times?
Maybe: Since we don't know, it becomes a matter of probability.
This does not follow. The number 0.01101010001010001010001000001... where the nth decimal place is 1 if n is prime and 0 otherwise never has a 5 in it, but it's still irrational.
Under the likely but hard-to-prove conjecture that pi is 10-normal, it contains the initial k digits of phi in order infinitely many times (for any k). Likewise for phi and pi.
No. In applying the infinite monkey theorem you are assuming phi is normal. Consider for example, the irrational number whose decimal expansion is 0.101001000100001... The probability of finding the sequence 314159 in the decimal expansion of this number is zero. The number I have chosen is not normal. We don't know if phi, or pi, or e is normal.
EDIT:
Dang. CRGreathouse beat me to the punch.
As CRGreathouse and D H pointed out, "irrational" is not enough. You need "normal number" and it is not know whether [itex]\pi[/itex] or [itex]\phi[/itex] is a normal number.
So Pi and Phi are not proven to be 'normal numbers', but if one wanted to speculate, it seems likely that they are normal, and thus subject to the Infinite Monkey Theorem?
Sounds like it Daniel,
Thanks to everyone else for entertaining the idea!
Essentially, yes.
Actually, it's one step better. The infinite monkey 'theorem' says that a random string of digits will eventually produce any given digit string with probability 1. If the number was normal, it will certainly contain any given digit string. All certain events have probability 1, but not all events of probability 1 are certain. For example, if you choose a 'random' real number, the probability that it's irrational is 1, but there are rational real numbers (just vanishingly few compared to the irrationals).
D H, I'm extremely amused to see that we posted at almost the same time, with almost the same conclusion, using the same argument with essentially similar irrational decimal expansions.
I've edited my response to include reference to D H.
  • · Replies 43 ·
  • · Replies 29 ·
10K
  • · Replies 29 ·
10K
  • · Replies 17 ·
