Complex Integral: Solve for pi.a coth(2.pi.a) - 1/2
The discussion revolves around the evaluation of a complex integral involving the function sin²(a.ln(z)) divided by (z - 1)², specifically aiming to show that it equals π.a coth(2π.a) - 1/2 for a > 0. Participants explore various contour integration techniques and methods to solve the integral.
  • One participant presents the integral and seeks help with complex contour integration methods.
  • Another participant clarifies the integral's form, suggesting it should be in terms of z rather than x.
  • Several participants discuss various contour methods, including key-hole contours and indentations around poles.
  • One participant mentions a reference to a book that confirms the result of the integral as π.a coth(2π.a) - 1/2.
  • Another participant proposes a different approach involving partial integration and convergence factors.
  • There are discussions about the challenges of writing mathematical expressions and the use of LaTeX for clarity.
  • One participant expresses uncertainty about the effectiveness of their proposed methods and seeks feedback from others.
Participants generally agree on the form of the integral and the proposed result, but there is no consensus on the methods to solve it or the effectiveness of the various approaches discussed. Multiple competing views and techniques remain present in the discussion.
Some participants express difficulty in following the mathematical expressions due to formatting issues, and there are mentions of specific methods not being widely covered in literature on complex integration.
Belgium 12
Hi,
I have a problem with the following complex integral.
Integral from 0 to+infinty sin²(a.lnz)/(x - 1)² = pi.a coth(2.pi.a) - 1/2 a>0
I tried different contours and methods,but without result.
Can you help me to find out the complex contour integration.
Thanks
Do you mean
[tex] \int_0^\infty{}\frac{\sin^2{(a \log z)}}{(z-1)^2}[/tex]
with z in the denominator instead of x. What contour did you try?
Welcome to PF!
Hi Belgium 12! Welcome to PF! :smile:
(do you mean (z - 1)² ?)
Hint: sin²θ = [1 - cos2θ]/2; and cos(2a ln(z)) = … ? :smile:
Yes that's the integral.
I tried a contour in upper half plane with an identitation at 1.
Then key-hole contour with the branch 0<phi<2.pi.
The a rectangular contour after the subtitution z= exp u
tanks
This would be
[tex] \frac{1}{2}\left[e^{2ia\log z}+e^{-2ia\log z}\right]=\frac{1}{2}\left[z^{2ia}+z^{-2ia}\right][/tex]
How does this help?
Hi,
I try it out and come later with a possible answer
Hi,
I have no result with cos(2alnz)=1/2(z exp2ia + z exp -2ia)
you have then sin²=(1-cos 2 phi)/2
thus 1/2{1- 1/2(zexp 2ia+zexp -2ia)}/ (x-1)²
We already have a second order pole on the real axis (x-1)²/2
I used the key-hole contour.
thanks
hi,
the result of the integral pi.a coth(2pia)-1/2 is correct.I saw it in a book "integral tables"
The integral with just the answer comes from a book in french "Recueil de problemes
sur la theorie des fonctions analytiques" by Evgrafov MIR publishers Moscow.
Hi,
tiny tim
Maybe I should try sin²(a.lnz)/(x-1)²=(exp 2ialnz -2 +exp2ialnz).-1/4/(x-1)²
ans with the term -2/(x-1) partial integration in the PV sence.
int from 1+e to infinty +int from 0 to 1-e.
Then the two other integrals 1)zexp2ia/(x-1)² and zexp -2ia/(x-1)² and the adding.
what's your opinion?
thanks
Hi Belgium 12! :smile:
Yes, that's what I was thinking of originally … it gives you something like:
[tex]\frac{\left[z^{2ia}+z^{-2ia}\,-\,2\right]}{4 (z\,-\,1)^2}\,.[/tex]​
Unfortunately, as Pere Callahan asks, does that actually get us anywhere?
I'm very rusty on contour integrals.
I suspect it has something to do with a quadrant integral, going down the positive real axis, up the positive imaginary axis, and then round in a huge 90º arc. But that still needs some way of (literally!) getting round the pole at z = 1. :confused:
Sorry … I'm stuck. :redface:
Hi,
Tiny Tim
Callehan
I found this in a bib,in a french book .Integral with double pole on the real axis.
It's a bit difficult for me for writing the math.expressions.I don't have latex or an other program.
Sorry for that
Hi Belgium,
I have to admit your file is too long for me to read right now ... and the math expression don't speed up the reading. Why don't you try learning latex (it's nothing about the keyboard, just some markup language, similar to HTML) and post your specific question about the method (if there are any)?
Hi,
Pere callahan
About your answer ysterday evening about the integral.I would say its not a specifc
method.Ist just a complex contour integration,but you don't see it many books on
The method is just they insert a convergence factor.
sin²(a.lnz)/(x-1)²=-1/4(z.exp 2ia -2 +z.exp -2ia)/(x-1)² they insert the factor let us say
z.expb
or -1/4(z.exp(2ia+b) -2.z.exp(b) -z.exp(-2ia+b))/(x-1)².
then integrate the three individual integrals take the sum en let b->0
that was it
Belgium 12
an then employ the formula
{int from o to 1-r xexp.a/(x-1)² + int from 1+r to inf. xexp.a/(x-1)² - 2/r}=-pi.a.cotg(pi.a)
to the three terms a=2ia and a=-2ia
Is this supposed to be part of thread https://www.physicsforums.com/showthread.php?t=227979&goto=newpost ? :smile:
yes that's is.
Belgium 12
I've merged the threads.
  • · Replies 21 ·
  • · Replies 27 ·
