Simple Harmonic Motion of a Pendulum
The discussion revolves around the simple harmonic motion of a pendulum, specifically focusing on the amplitude derived from the given angular displacement equation. The original poster seeks clarification on the amplitude in relation to the pendulum's motion described by the equation (.10 rad)cos(5t + pi).
  • Participants discuss the identification of the initial angle and its implications for determining amplitude. There is also a focus on the correct interpretation of the displacement and angular amplitude in the context of simple harmonic motion.
Participants are actively engaging in clarifying the definitions of amplitude and displacement. Some guidance has been offered regarding the identification of angular amplitude and the nature of the displacement along the pendulum's path. Multiple interpretations of the values discussed are being explored.
There is a mention of the small angle approximation and its relevance to the calculations being performed. The discussion also highlights potential confusion regarding the signs in simple harmonic motion equations.
bcjochim07
What is the amplitude of a pendulum whose angle is given by (.10 rad)cos(5t + pi)
where t is in sec.
s(t)=Acos(omega*t+phase constant)
Theta(t)=thetamax*cos(omega*t+phase constant)
I'm not quite sure if I did this right:
I found the length of the string to be .392 m ( by using omega= sqrt(g/L)
So, using the small angle approximation s= .392 * sin theta where theta= the intial angle, which I found to be .1 rad by looking at the equation
s=(.392*sin(.1rad)) = .039 m
Then I used s(t) =Acos(omega*t + phase constant) with t=0
I also found omega= 5 and the phase constant is pi
.039 m = A cos(pi)
But my amplitude ends up negative. I've having a bit of trouble with positive and negative signs in SHM
Hi bcjochim07,
I think there are several things that are not quite right. The first and maybe the cause of the others is your identification of 0.1 radians as the initial angle. (The initial angle would be found by setting t=0 and solving for theta.)
So what would you say the angle 0.1 radians is? (It's actually mentioned in your formula for theta(t).)
Another issue that does not lead to a numerical error is that you used
s= r sin(theta) to find s=0.039 m
This gives the correct numerical value because theta is small (as it has to be for the pendulum to be in SHM), but s is actually the arc length along the pendulum's circular path so we would have
s = r theta
But the number you get looks right; now identify what that number represents (because of the particular angle that you used).
Actually theta = (.10 rad)cos(5t + pi) is the expression for the pendulum with the variable the angle.
so 0.10 rad is the amplitude.
Hi bcjochim07,
In my two posts I asked you for the identification of two values that you found. The angle you found was the angular amplitude (as SimonZ stated) and the other (0.039 m) is the displacement amplitude (along the arc).
  • · Replies 51 ·
  • · Replies 25 ·
  • · Replies 23 ·
