Magnetic field produced by a solenoid
The magnetic field produced by a solenoid is defined by the equation B = μ₀NI, where N represents the number of turns per unit length. A simplified model expresses the magnetic field as B = (μ₀nVA) / (ρLₛLₗ), incorporating wire length, voltage, and material properties. The discussion highlights that the magnetic field strength also depends on the density of the windings, which is determined by the number of turns per inch along the coil. This indicates that both the solenoid's length and winding density are crucial factors in determining the magnetic field strength.
  • Understanding of electromagnetism principles
  • Familiarity with solenoid design and construction
  • Knowledge of Ohm's Law and resistivity concepts
  • Basic calculus for evaluating arc length and integrals
  • Explore the effects of wire material on magnetic field strength in solenoids
  • Learn about standardized winding densities and their impact on solenoid performance
  • Study advanced solenoid design techniques for optimizing magnetic fields
  • Investigate the relationship between voltage and magnetic field strength in solenoids
Physics students, electrical engineers, and hobbyists interested in electromagnetism and solenoid applications.
Nabeshin
Ok, so anyone who has studied magnetism knows that the magnetic field due to a solenoid is given by the equation [tex]B=\mu_oNI[/tex] Where N is the number of turns in a given length. Well, in thinking about these, I tend not to make measurements and would rather like to predict the magnetic field of the solenoid, so I tried to "simplify" the formula. Here goes:
N is turns, which I call n per length, which I will call [tex]L_s[/tex]
[tex]B=\frac{\mu_onI}{L_s}[/tex]
From ohms law, I = V/R
[tex]B=\frac{\mu_onV}{L_sR}[/tex]
And R is equal to [tex]\frac{\rho L_w}{A}[/tex] Where [tex]L_w[/tex] is the length of wire and A is its cross-sectional area.
[tex]B=\frac{\mu_onVA}{\rho L_s L_w}[/tex]
Up till here I'm confident, but after this I'm not so sure. Now, I tried to model the helical nature of the wire wrap by creating a vector-valued function:
[tex]r(t)=sin(t)i-cos(t)j+\frac{r_w}{\pi}t k\left[/tex]
Now in doing this I assume that the coils are wrapped as tight as possible. By this I mean that the horizontal spacing between two loops is equal to 2r, or the diameter of the wire. So this function should move a distance of 2r up for every turn (2*pi radians).
Now, arc length is given by the formula: [tex]s(t)=\int||r'(t)||dt[/tex] So...
[tex]s(t)=\int\sqrt{sin^{2}(t)+cos^{2}(t)+(\frac{r_w}{\pi})^{2}}dt[/tex]
Now, in one turn of the wire we rotate 2pi radians, so let's evaluate from 0 to 2pi..
[tex]s(t)=\int^{2\pi}_{0}\sqrt{sin^{2}(t)+cos^{2}(t)+(\frac{r_w}{\pi})^{2}}dt=2\sqrt{\pi^{2}+r^{2}}[/tex]
So this is the length of wire per one turn, so we can say:
[tex]\frac{Length\<img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":o" title="Eek! :o" data-smilie="9"data-shortname=":o" />f\:wire}{Turn\<img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":o" title="Eek! :o" data-smilie="9"data-shortname=":o" />f\:wire}=2\sqrt{\pi^{2}+r^{2}}[/tex]
And turns of wire is n, so we finally arrive at:
[tex]L_w = 2n\sqrt{\pi^{2}+r^{2}}[/tex]
Back to the main mission! Substituting in for [tex]L_w[/tex] produces:
[tex]B=\frac{\mu_o A V}{2\rho L_s\sqrt{\pi^{2}+r^{2}}}[/tex]
So I gather that the magnetic field of a solenoid depends on three things: How long the solenoid is, the specific wire you're using (both size and material), and the voltage applied. Well, does this make sense to anyone? :smile:
Accept that you left out the fourth thing. Strengthen the magnetic field is a function of "field density." And the density of the field is determined by the number of turns in the coil per inch of links along the coil. So, the field strengths does not only depend on the length of the coil, but also the density of the windings. Unless, of course, you're talking about a standardized winding density, in which case length of the coil is all that matters.
Well, I assumed the coils were right next to each other which is as tight as they can get, which I think is what you mean by standardized winding density.
  • · Replies 16 ·
  • · Replies 29 ·
  • · Replies 26 ·
