How Can I Prove That QxQ is Disconnected and Totally Disconnected in R²?
  • Context: Graduate
  • Thread starter Thread starter Dani4941
    Proof Sets
The discussion revolves around proving that the Cartesian product of the rationals, Q x Q, is disconnected and totally disconnected within R². Participants explore definitions and approaches related to connectedness in metric spaces, seeking clarity on the proof structure and underlying concepts.
  • One participant suggests that Q x Q can be shown to be disconnected by separating points into two disjoint open sets, but expresses confusion about the definitions and the nature of these sets.
  • Another participant questions the validity of the proof, emphasizing that the argument must leverage the differences between the rational and real numbers, as R² is connected.
  • A participant introduces an alternative definition of disconnectedness, stating that a set is disconnected if it contains a proper nontrivial subset that is both open and closed.
  • There is a discussion about the implications of using sequences and the properties of rational numbers, such as the lack of completeness compared to real numbers.
  • One participant points out that if the proof for Q x Q does not differ from that of R², then it cannot be correct, suggesting the need for a more nuanced approach.
  • Another participant proposes demonstrating that certain subsets of Q x Q are both closed and separated to establish total disconnectedness.
  • Clarifications are sought regarding the definitions of connectedness and the conditions under which sets can be considered disconnected.
Participants express differing views on the definitions and approaches to proving disconnectedness. There is no consensus on the proof structure, and multiple competing interpretations of connectedness are present.
Participants highlight the importance of distinguishing between open and closed sets in the context of disconnectedness, as well as the need to consider the properties unique to rational numbers versus real numbers.
Dani4941
I have to present it in front of the class so I’m trying to make it as clean and correct as possible.
If someone could just point me in the right direction for this proof or give me some examples that would be great.
(Sorry if this is sloppy but I’ll try to make it as nice as possible)
The problem I'm having trouble with is.
1 Prove that QxQ c R² (The Cartesian product of the rationals in R²) is disconnected
2 Show it is totally disconnected
So far for 1 I have
Let qЄQ
By the Cartesian product we would get a sequence
(q1, q1), (q2, q2), (q3, q3),…,(qn, qn)
(This is where it gets a bit confusing and sloppy. I don’t know if I can take (q1, q1) and just represent it as q)
The numbers in the sequence can be separated as
{x | x > q}∩U1, {x | x < q}∩U2
Therefore by the definition of connected sets it is disconnected
2.
For Q x Q to be totally disconnected it has at least two points and for all distinct points p1, p2 in S, the set S can be separated by two disjoint open sets U1 and U2 into two pieces S∩U1 S∩U2 containing p1 and p2
(q1, q1) Є U1
(q2, q2) Є U2
(q1, q1), (q2, q2) Є S
Therefore they are totally disconnected.
So far for 1 I have
Let qЄQ
??What are U1 and U2? and what definition of "connected sets" are you using?
2.
(q1, q1) Є U1
(q2, q2) Є U2
Again, WHAT are U1 and U2? If you are saying they are the "two disjoint open sets U1 and U2" you mention above, then you are assuming the set is disconnected to begin with.
Since R2 is connected and you are trying to prove that Q2 is NOT, it seems to me your proof had better make use of the difference btween R and Q- and I don't see that anything you have done here wouldn't apply to R2 as well.
Sorry the def I'm using is
A set is connected if it cannot be separated by two disjoint sets U1 and U2 into two nonempty pieces S∩U1 and S∩U2
Sorry I don't understand what you're saying. I'm not being sarcastic I'm just trying to get what you mean.
Since we are talking about metric spaces, an equivalent definition of disconnected is that it contains a proper (and nontrivial) subset that is both open and closed (this is equivalent because then its complement is also both open and closed and these are disjoint)
With this definition, a totally disconnected subset is one whose only connected subsets are the empty set and any singleton sets. (i.e., if you have any set with more than 1 element in it, then it is disconnected)
Showing that Q^2 has a proper, non empty, subset that is both open and closed is pretty easy, you just need to demonstrate one. Showing that every subset of Q^2 with more than 1 element is disconnected is a little more difficult. I remember doing it, but I can't quite remember how at the moment.
Thanks. I'm pretty sure I've been making this proof seem much harder then it actually is.
What I meant was that the set of real numbers (and so R2) is a connected set. Q2 is not connected essentially because Q is not. If replacing "Q" by "R" in your proof doesn't change the result, it can't be correct! So your proof had better involve some way in which the rational numbers are different from the real numbers.
For example, the fact that every bounded set of real numbers has a least upper bound is not true for rational numbers, the "monotone convergence theorem" is not true for rational numbers (at first, since you were using sequences of points, I thought that was what you were using), Cauchy sequences of rational numbers do not converge (to a rational number), etc.
One simple difference is that [itex]\sqrt{2}[/itex] is NOT a rational number. In other words, Q2= QxQ is the union of {(x,y)|x,y[itex]\in[/itex] Q, y>0, y^2> 2} and {(x,y)|x,y[itex]\in[/itex]Q, y^2< 2}. Can you show that those sets are both closed and so separated?
That's incorrect. Any set with 2 or more points can be separated like that. You need two "separated" sets (U1 closure∩ U2 and U1∩ U2 closure are empty), not just "disjoint", or else "U1, U2 both closed sets" or "U1, U2 both open sets".
  • · Replies 25 ·
