Spring Compression: 2.5kg Block + 4.5kg Block
The problem involves a 2.5 kg block sliding towards a stationary 4.5 kg block, with a spring attached to the second block. The scenario explores the dynamics of the collision and the subsequent compression of the spring, governed by Hooke's law.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of conservation of momentum and energy to analyze the collision and spring compression. There are attempts to calculate the velocity of the second block post-collision and questions about the nature of the collision (elastic vs. inelastic).
Participants are actively exploring different interpretations of the problem, particularly regarding the conservation laws and the relationship between the blocks' velocities at maximum spring compression. Some guidance has been provided about the assumptions related to momentum transfer and the nature of the collision.
There is mention of the collision being perfectly elastic, which may influence the calculations regarding energy and velocity relationships. Participants are also considering the implications of this assumption on their approaches.
Oomair
A 2.5 kg block slides along a frictionless tabletop at 6.0 m/s toward a second block (at rest) of mass 4.5 kg. A coil spring, which obeys Hooke's law and has spring constant k = 860 N/m, is attached to the second block in such a way that it will be compressed when struck by the moving block
i first used M1V1 = M2V2, M2 is the block at rest, i calculated the speed of block at rest and i got 3.33 m/s, and then i use the energy equations to find the spring compression
.5 m1(6)^2 = .5k(x^2) + .5m2(3.33)^2, i solve for x, but it comes out wrong, anything I am missing here?
You forgoet to mention what the question was asking, but...You should be able to forget the first blcok after the collision. I would just use momentum conservation to find the velocity of the second block after the collision. Then the kinteic energy associated with this velocity will be converted completely to the potential energy to be stored in the spring once its compressed.
in other words, 1/2mv^2 = 1/2kx^2 (all for the second block), where v is the velocity of the second block after the collision, or the start point of the new system.
Edit: you might also want to see if the collision is completely elastic or not, because this would change your answer
This assumes that all the momentum of the first block is transferred to the second. That's not true.
I assume you are trying to find the maximum spring compression. Hint: How will the velocities of the two blocks be related when the spring is at maximum compression?
(But you are correct to be using conservation of momentum and energy. So you are close.)
The book is saying that the collision is perfectly elastic, but I am confused on how i would relate the speeds in terms of energy
Yes, the collision is perfectly elastic. You'll need that fact later.
When the spring is at maximum compression, what must be the relative speed of the two blocks?
