| Thread Closed |
Solving the triangle |
Share Thread |
| Apr20-08, 07:07 PM | #1 |
use the information to solve the triangle: b=1, c=the square root of (3)+1, B=15 degrees. given that sin15 degrees =the square root of 6 -the square root of 2 divided by 4. FYI.. is in the square root and than add one. 2. Relevant equations The formulas given the law of sin sinA/a=sinB/b=sinC/c The law cosine 3. The attempt at a solution I used the law of sin to find angle C. The problem is written out as the square root of (3)+1 Sin(15)/1. I came out with .70 degrees for angle c. For some reason I can't get that answer again. Also I'm not sure which formula I should be using. |
| Apr21-08, 03:59 AM | #2 |
Recognitions:
Well using the sine rule, we get [tex] \frac{\sin 15*}{1} = \frac{\sin C}{\sqrt{3}+1}[/tex].
The * I used to denote degrees. Anyway, to get the angle C, we must get Sin C by itself on one side. Once you do that, simplify the Sin 15 degrees from what it gave you in the question, and also take out a factor of sqrt2 from it. Then it should simplify very nicely, you shouldn't even need a calculator for it. You get some nice common angle, not 0.70 degrees. |
| Apr21-08, 05:41 AM | #3 |
msdenise15, you forgot to take the arcsine! What you calculated was that sin(C)= .707..= sqrt(2)/2. And, as Gibz said, that's a "well known" angle.
| Thread Closed |
Similar discussions for: Solving the triangle
| 3-4-5 triangle | Precalculus Mathematics Homework | 9 | ||
| About a triangle.... | Introductory Physics Homework | 6 | ||
| help with triangle | Introductory Physics Homework | 1 | ||
| triangle help | General Math | 1 | ||
| EM Triangle | General Physics | 1 | ||
