Calculating the Volume of a Bubble at Different Depths in the Sea
  • Thread starter Thread starter zcabral
    Bubble Volume
The discussion focuses on calculating the volume of an air bubble exhaled by a diver at a depth of 24.0 meters in seawater, with a density of 1025 kg/m³ and a temperature of 5.00°C. The diver's initial bubble volume is 1.20 cm³, and the problem requires determining its volume just before breaking the surface at a temperature of 20.0°C. Participants emphasize the necessity of using the Ideal Gas Law and absolute temperatures in Kelvin for accurate calculations, along with understanding hydrostatic pressure, which combines the pressure from the water depth and atmospheric pressure.
  • Understanding of the Ideal Gas Law
  • Knowledge of hydrostatic pressure calculations
  • Familiarity with absolute temperature conversions (Celsius to Kelvin)
  • Basic principles of buoyancy and gas behavior under pressure
  • Study hydrostatic pressure calculations in fluid mechanics
  • Learn about the Ideal Gas Law and its applications in real-world scenarios
  • Explore temperature conversions and their importance in gas volume calculations
  • Investigate the effects of pressure changes on gas volumes in different environments
Students in physics or engineering, scuba divers, and anyone interested in understanding gas behavior under varying pressure and temperature conditions.
zcabral
At 24.0 m below the surface of the sea (density = 1025 kg/m3), where the temperature is 5.00°C, a diver exhales an air bubble having a volume of 1.20 cm3. If the surface temperature of the sea is 20.0°C, what is the volume of the bubble just before it breaks the surface?
cm^3
P1V1/T1=P2V2/T2 (thats what i tried)
i got answers like 4.8, 1.68 by plugging into the equation...but as usual plug and chug never works...can u help please? i think I am missing how to find pressure from 24 m below surface. how do u do that?
It would be more helpful to a reader here if you showed the calculations you made, rather than simply giving the answers you found that didn't work. You do want to use the "Ideal Gas Law". Did you use absolute temperatures in your calculation (Kelvins, rather than degrees Celsius)? Did you remember that the pressure at 24 m. down is the hydrostatic pressure of 24 meters of water plus the one atmosphere of pressure from the air above the water's surface?
Have you had the topic on hydrostatic pressure? The pressure from the water will be
P = (density of water) x (g) x (depth of water).
no we haven't covered that so wat pressure wud i used for when its just about to break the surface of the water since i don't know exactly how deep it is? wud that just be 1 atm?
