Register to reply
Two particles having charges separated by a distance
by sonrie
Tags: charges, distance, particles, separated
Share this thread:
sonrie
#1
Apr22-08, 10:50 PM
P: 35
Two particles having charges of 0.600 nC and 5.40 nC are separated by a distance of 1.30 m.
A.) At what point along the line connecting the two charges is the net electric field due to the two charges equal to zero?
the electric field is zero at a point _______ m from .600nC
i found out the answer to this to be .325m. by doing the following:
E due to q1 is equal in magnitude to E due to q2 but in opposite direction
As both q1 and q2 are positive, the field is zero at a point in between them
As distance from q1 is L , distance from q2 is (1.3 - L)
kq1/L^2 = kq2/(1.2 - L)^2
(1.3 - L) / L= sq rt (q2 / q1)
(1.3 - L) = L* sq rt (q2 / q1)
1.3 = L [1+sq rt (q2 / q1)]
L = 1.3 / [1+sq rt (q2 / q1)]
L = 1.3 / [1+sq rt (5.40 / 0.600)]
L = 1.3 / [1+sq rt ( 9.00 )]
L = 1.3 / [1+ 3.0]
L = 1.3 / [ 4.0]
L=0.325 meter from 0.550 nC
Where would the net electric field be zero if one of the charges were negative.
Enter answer as a distance from the charge initially equal 0.600 nC . This is where i get lost, i don't know what to do next. please Help!
__________________
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
Phlogistonian
#2
Apr22-08, 11:11 PM
P: 87
You do it like you did the first one. Start with
[tex]\vec{E_1} + \vec{E_2} = 0[/tex]
Be careful about the vector directions.
sonrie
#3
Apr23-08, 09:41 AM
P: 35
should the answer be the same but just negative since i using the same values as before?
Phlogistonian
#4
Apr23-08, 10:14 AM
P: 87
When I wrote, "You do it like you did the first one," I meant, you start it the same way. The algebra is different.
I apologize; I should have been clearer.
sonrie
#5
Apr24-08, 04:31 PM
P: 35
Thanks A Bunch!
Phlogistonian
#6
Apr24-08, 04:52 PM
P: 87
You're welcome.
Register to reply
Related Discussions
Finding charges using electric field and distance Introductory Physics Homework 10
Distance between two charges where field strength = 0 Introductory Physics Homework 9
Finding the distance of 2 charges Introductory Physics Homework 0
Distance between charges. Introductory Physics Homework 3
Distance between charges Introductory Physics Homework 1
