Proving and Disproving a Mathematical Problem: Adding Numbers in Any Base
  • Context: Undergrad
  • Thread starter Thread starter marisolm
The discussion revolves around a mathematical problem concerning the addition of digits in any base, specifically whether the sum of the digits of a number in a given base will always yield a result that is one less than the base itself. Participants explore the validity of this claim, its implications, and its connections to various branches of mathematics.
  • One participant proposes that the sum of the digits of a number in any base will always yield a result that is one less than the base, prompting questions about the validity and application of this claim.
  • Another participant challenges the clarity of the problem, questioning how to interpret the addition of digits and whether the claim holds in all bases.
  • A participant mentions the concept of "casting out nines" in base 10, suggesting a relationship between digit sums and remainders when divided by the base minus one.
  • One reply provides a detailed method for calculating the digit sum and its relationship to the base, emphasizing the importance of consistency in mathematical operations across different bases.
  • Another participant explains that the claim can be proved using algebra and modular arithmetic, specifically referencing the divisibility of certain expressions by the base minus one.
  • There is mention of the historical context of number theory and its perceived lack of practical applications, alongside a reference to RSA encryption as a counterexample.
  • Some participants express uncertainty about the practical applications of the claim, while others assert that it falls under the domain of number theory.
  • One participant suggests that the proof could be easily constructed with basic tools, while another emphasizes the utility of modular arithmetic in the proof process.
Participants do not reach a consensus on the validity of the original claim. While some provide supportive arguments and potential proofs, others express confusion and challenge the clarity of the problem. Multiple competing views remain regarding the interpretation and implications of the claim.
Participants note the importance of consistent mathematical operations across different bases and the potential for negative values during digit addition, which may complicate the proof process. The discussion also highlights the need for clear definitions and examples to avoid misunderstandings.
marisolm
PROBLEM: For any number in any base at least 2 digits long, if you add them together and solve it the answer will ALWAYS be 1 number less than the base itself.
Why this problem works out?
Does it apply to anything?
What branch of Mathematics?
Prove in General sense or disprove.
HELP! :eek:
'solve'? what do you mean? post an example.
I asked and solve it just means figure out if it works or not...
your question still doesn't make sense at all.
take 11 (we won't say what base), what must we do to it now? what on Earth do i add together? the only thing can i can think of is the digits in the number, so i add them and get 2, now in any other base than 3, that cannot be one less than the base, so what on Earth are you talking about? at least attempt to indicate what the referents of all those undetermined pronouns are.
I'm going to email my prof. and make sure I copied the question down right. i'll re-post it as soon as I hear from him. Thanks for your interest in helping.
It is true that if you add all the "digits" in a number (in any base) and repeat until you are down to one digit, that digit will be the remainder when the original number is divide by the base minus 1. In base 10, it's called "casting out nines".
I asked my teacher for an explanation and this is what he gave me...
Choose a number in any base that is two or more digits long.
Add all the digits together and keep adding until you have 1 single digit.
remember to add in the rules for the base you've chosen.
Eg: Base 10
743=7+4+3=14=1+4=5
Take your original number (above it's 743) and subtract the "sum"
743-5=738
"Add" this "sum" together until you have 1 digit (as above)
7+3+8=18=1+8=9
This number is always one less than the base you're working in.
Note: Your math MUST be consistent for the base you're working in!
well, now you've explained it it becomes reasonably obvious if you're happy with modulo arithmetic. as hallsofivy states the number you calculate in this operation is the reaminder modulo the base minus one, so subtracting it leaves a number that has zero remainder modulo the base minus one.
Your questions still appear, largely, unanswered... so let me fill in a little more :
1. Why it works out can be proved using algebra and the representation of a number in a base, b as :
sum [a(k) b^k], k=0,1,..n.
It's easy to prove the part that hallsofivy stated. That comes from (b^m - 1) being divisible by (b-1); b being the base. The next step is to prove that the (sum of digits of a multiple of (b-1)) = a multiple of b-1. The only trick here is in noticing that some digits look like a(k) - a(k-1), which can be negative. So, you need to carry over a 'b' from the previous digit (to make it non-negative) while adding digits, and then everything will be okay.
2. Does this apply to anything ? Yes, it applies to all numbers in Z. But if you're asking if it has any practical applications, I'm not sure I know any. Didn't Hardy once say that he felt secure that Number Theory would never be defiled by the common man, because it had no known applications ? RSA sure proved him wrong !
3. I guess you might say this came under number theory.
4. It can be proved (in the affirmative). For hints, see the answer to 1. If you really want to see the whole proof, I'll do it when I find an equation editor I can paste off of.
Equation editor? Why? Five minutes, and one pencil ought to do. The proof can be easily filled in from what has been written. Easily means after a day of thinking.
Actually, it's easier to prove using modular arithmetic, particularly, b^k==1 (mod b).
  • · Replies 105 ·
12K
11K
