Register to reply
Need help converting battery clock to DC
by grime
Tags: battery, clock, converting
Share this thread:
grime
#1
Apr27-08, 04:17 PM
P: 3
I have a clock that eats up the batteries it runs on pretty quickly, and so I would like to convert it to run on DC power.
The clock has a total of 2 D batteries, 1 in each "foot" of the clock (they are separate). There is a white wire that starts at the + side of one battery, goes over to the + side of the other battery, then into the motor. There are 2 black wires that connect to each - side of each battery and then into the motor. The 2 black wires do not connect to one another (unless it is inside the motor assembly).
Can anyone assist in getting me started?
Thanks in advance.
Phys.Org News Partner Engineering news on Phys.org
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
New filter technology uses inert gas to bore holes in high-quality steel
russ_watters
#2
Apr27-08, 04:51 PM
Mentor
P: 22,298
Batteries are DC. You mean you want to use an AC to DC power source?
It sounds like the batteries are in parallel, but it is tough to know without tracing out the black wires. But once you do figure that out, you can get a power supply at Radio Shack to provide the needed 1.5V or 3V power.
Welcome to PF.
grime
#3
Apr27-08, 05:49 PM
P: 3
Thanks for the quick reply, Russ.
So if it's parallel, I need 1.5V, correct? Does the amperage of the power supply matter at all?
TVP45
#4
Apr27-08, 06:12 PM
P: 1,127
So, take one battery out and see if it still runs OK. If the batteries are in parallel, it's just for longer-lasting battery life.
HarryZhe
#5
Apr27-08, 06:54 PM
P: 8
Id like to see the answer to this as well, as I'm considering setting up an instrument to take energy sources toggle-able between its native batteries and a modded 240 adaptor.
grime
#6
Apr27-08, 06:56 PM
P: 3
It seems to run fine on 1 battery, so it looks like they are in parallel.
russ_watters
#7
Apr27-08, 08:53 PM
Mentor
P: 22,298
Quote Quote by TVP45 View Post
Duh, I should have thought of that.
JGM_14
#8
Apr28-08, 10:39 AM
P: 158
Quote Quote by grime View Post
Yes, typically D cell batteries supply higher amperage and amp hours (battery life). If it runs fine on AAA batteries or smaller then amperage is not a problem but it sounds like a higher amperage clock, 1 amp should be enough.
HarryZhe
#9
Apr28-08, 06:13 PM
P: 8
Quote Quote by JGM_14 View Post
Im not meaning to hijack your thread here but seeing as this guy seems to know what he's talking about and only one guy's posted help in my thread, how would this work out for 4xAA in series?
Register to reply
Related Discussions
A battery-battery-resistor circuit Introductory Physics Homework 2
A moving clock lags behind a stationary clock Special & General Relativity 2
Converting mph Introductory Physics Homework 6
Clock in clock shop General Discussion 11
I need help converting kg/s! Introductory Physics Homework 4
