Thread Closed
photo voltaic cell Vs. solar heating panel
Share Thread Thread Tools
Apr29-08, 01:23 PM   #1
i've been asked to compare the efficiency of a photo voltaic cell and a solar heating cell (an array of pipes). both will be exposed to a 150W bulb for an equal amount of time.
2. Relevant equations
for photo cell: P=IV
for heating panel: P=fcT f=flow rate c=specific heat capacity T=change in temp
3. The attempt at a solution
im trying to say that both will have the same surface area exposed to the light, i was just wondering what measurement to use for the pipes: the surface area of the pipes that is exposed, or the area of the whole panel??
any other suggestions would be welcome :D
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Apr29-08, 01:37 PM   #2
Recognitions:
Homework Helper Homework Help
I wouldn't worry about the actual surface area of the pipe. You are comparing a practical installation so the only consideration is the total floor (or roof!) area available for installation.
Using a tugsten light bulb isn't a good model for the sun, it lacks the shorter wavelength blue and UV light that the solar panel is sensitive to.
Can't you put both outside at the same time pointing in the same direction?
That would also allow you to compare their relative efficency at best - sun pointing directly at them, vs worst - sun on horizon.
Apr29-08, 01:45 PM   #3
yeah, i guess youre right, if im comparing the panels i should just use the area.
we've been told to use a lightbulb, i know the actual sun would deliver a more useful result, but the bulb is what we're given.
now that im thinking about it, im not quite sure what to use as the independent variable. would the different panels be enough?
Thread Closed
Thread Tools
Similar Threads for: photo voltaic cell Vs. solar heating panel
Thread Forum Replies
Solar Panel testing Electrical Engineering 6
Working of Voltaic cell Chemistry 10
45 W solar panel Engineering Systems & Design 1
Why does copper wire work as a salt bridge in a voltaic cell? Biology, Chemistry & Other Homework 0
Working of Voltaic cell Classical Physics 1
