How do I find the laplace transformation of i(t)=(t)(e^t)(sinkt)?
  • Context: Undergrad
  • Thread starter Thread starter mak_wilson
    Laplace Transformation
The discussion revolves around finding the Laplace transformation of the function i(t) = (t)(e^t)(sin(kt)). Participants explore various methods and challenges associated with solving this integral, focusing on the complexity of the problem.
  • Homework-related
  • One participant requests help with finding the Laplace transformation of the given function, expressing uncertainty about how to proceed.
  • Another participant provides the definition of the Laplace Transform and sets up the integral, noting its complexity and suggesting that convolution may be relevant.
  • A participant acknowledges the complexity of the integral and expresses difficulty in solving it due to the presence of multiple t factors.
  • One participant suggests using integration by parts to simplify the integral, assuming s > 1, and mentions that the integral of e^((1-s)t)sin(kt) can be managed with this method.
  • Another participant recommends using the complex exponential to simplify the calculation, indicating that this approach yields two Laplace transforms simultaneously.
  • A later post offers a solution without detailing the steps, prompting a thank you from another participant.
Participants express varying levels of confidence in their approaches, with some suggesting methods while others indicate uncertainty. There is no consensus on a single method or solution to the problem.
Participants mention assumptions such as s > 1 and the potential use of convolution, but these assumptions are not universally accepted or explored in depth.
Individuals interested in Laplace transformations, particularly those facing similar mathematical challenges in their studies or applications.
mak_wilson
please help me with this question
Find the laplace transformation of this function
i really don't know how to do!
The Laplace Transform is defined as:
[tex]Y(s) = \int_{0}^{\infty} e^{-st}y(t)dt[/tex]
where y(t) is the function you wish to find the Laplacian of.
In this example, the integral would be:
[tex]\int_{0}^{\infty} te^{-st}e^tsin(kt)dt[/tex]
...which is unbelievably ugly.
Have you learned about convolution yet? This is a pretty nasty problem, unless I'm missing something, which it seems probable that I am.
thz
You didnt miss anything, i can do up to this stage, but it contain 3 t in it, I don't really know how to solve it!
1. Since the integral of the e^((1-s)t)*sin(kt) will "rotate" during integration by parts (i.e. you will gain back a multiple of what you began integrating), evaluating the integral of this function alone should pose no problems.
(Assuming s>1, that is)
2. You can now go back to the original problem, using integration by parts to eliminate the t-factor.
3. Alternatively, you might use the complex exponential as a simplifying measure.
That's what I would do, too. The beautiful thing about that is that, not only is it a lot easier to calculate, but it also gives you TWO Laplace transforms simultaneously.
mak_wilson, I would recommend that you take this suggestion. Make the replacement:
sin(kt)--->eikt
and take the imaginary part at the end.
solution
Here is a solution,
Max.
thank You~~
  • · Replies 17 ·
  • · Replies 19 ·
