| Thread Closed |
Another warming question |
Share Thread |
| May6-08, 10:22 AM | #18 |
| May6-08, 10:59 AM | #20 |
Andre you know that those linear trends are extremely sensitive to the '98 data point. What happens to the trend once you've established reasonable insensitivity to end-points? It is meaningless to speak of a trend otherwise.
| May6-08, 11:09 AM | #21 |
The trend is also extremely sensitive to removing the deep dip immediately following the spike of 1998. But perhaps we could conclude that it's not safe to say that warming over the last decade has been stronger than over the last 50 years
| May6-08, 11:27 AM | #22 |
2. I've looked at the data with and without outliers of different strengths (2, 3, 4 standard deviations away from mean), and with each additional removal of outliers, the slope either increased significantly or changed very little. But even if you look at the 5 trend-lines as you have them in the linked post, with all outliers included, the average slope is 0.5K/cent, which is the same as the warming trend over the previous 50 or so years. Eliminating outliers or expanding the dataset and thus reducing the error bar on the trend to actually meaningful values gives a number that is roughly twice as big. I admit that I should have been a lot more careful with my statement about the recent warming data. While the trend is positive to a high degree of confidence, the confidence level is much poorer in the difference with the trend over the previous 50 years. |
| May6-08, 12:37 PM | #23 |
) for eg It seems your argument is a statistical one based on if you squint your eyes a certain way whilst looking at gently massaged, cherry picked data you can at a stretch perhaps argue the temp hasn't actually fallen. That's what I meant about AGW proponents desperately clinging to a failed hypothesis. btw What did you do with the 'abnormal' global cooling figures of the 70's when creating your 50 year trend lines? |
| May6-08, 12:43 PM | #24 |
Perhaps have a look at the maximum extent of the data, the last 29 years, when in 1979 the satelites became operational.
http://gallery.myff.org/gallery/2451...rected-29y.PNG Some see a bit of a cycle emerging here, with lows in the late 1980s and highs in the early 2000's. of course in a cycle you can generate any trend. More interesting still is to figure out why GHCN and NOAA keep on warming while the other three clearly break with the trend. |
| May6-08, 01:12 PM | #25 |
| May6-08, 01:36 PM | #26 |
You could probably start a thread about just this. I haven't seen a thread that is dedicated directly to how the different datasets are generated, and I don't think I'm the only one that is interested in learning about this. |
| May6-08, 02:18 PM | #27 |
Gokul as you are a statistician can you explain how you can make comparisons between 'corrected' data from the past 10 years and 'uncorrected' data from the previous 50 and then draw a conclusion as to how one relates to the other as it seems to a non-statistician like me to be like a comparison between apples and oranges. The 1951 - 1980 data set commonly used to establish the base line of 14 C includes the 'manmade' (sic) anomalous cold period of the 70's. What happens to the 50 year trend if you 'correct' the data to remove these 'outliers' ?
I would also like to know how you identify an outlier anyway. Is there a presumption that some special event caused an extraordinary variation? but if so how do you know the 'normal' variation data points aren't themselves made up of two or more extraordinary events which happen to 'almost' cancel each other out especially in such a complicated system as our climate? It is the inclusion of some 'anomalous' data points and the targeted or spurious removal of others that I referred to as cherry picking. |
| May6-08, 03:46 PM | #28 |
| May7-08, 02:05 PM | #29 |
Sorry that I haven’t been able to get back to this before now. Thanks for the mention of the peer reviewed cooling thread which I hadn’t properly taken in. I see the word ‘cooling’, taken from the link, in the OT, is debatable as are the patterns and aberrations. To debate this is beyond me, but I am very grateful for the valuable discussion, and look forward to further discussion on more data.
| May8-08, 10:56 AM | #30 |
And we will keep the discussion alive Ff, as for instance we talked about Antarctica earlier. This would also add to that part:
http://www.ucar.edu/news/releases/2008/antarctica.jsp |
| May8-08, 11:43 AM | #31 |
| May14-08, 10:24 AM | #32 |
It appears that those here who insist that the Earth is warming are being very selective in their choice of source material.
Of the four global temperature gathering groups, three of the four report stasis in the last 10 years. Hadley Cru (sp?) from the UK show no warming since 1998. Both satallite measuring sites show stasis to slight cooling. Only Nasa shows warming based on questionable ground based sites (mostly in the United States...hardly any in the Southern Hemisphere). If all four sites are used one would seriously have to doubt the validity of any statement that the Earth is warming at all in the last 10 years despite the increase in the perported "driver" CO2. So is it truely scientific to cherry pick the site that agrees with ones opinion? |
| May14-08, 11:01 AM | #33 |
| May14-08, 11:29 AM | #34 |
I have actually done that in my field which is Geology with Paleo emphasis. It was rejected on the grounds that it didn't meet current understanding of climate forcers.
I have discovered that both Nature and Science will not accept any paper that seriously disputes the company line of AGW. |
| Thread Closed |
Similar discussions for: Another warming question
| A Global Warming Question | Earth | 4 | ||
| global warming | Earth | 0 | ||
| How can anyone question man's significant role in global warming? | Earth | 86 | ||
| global warming | Earth | 5 | ||
| question about global warming | Earth | 6 | ||
