Understanding Constraint Forces in Mechanics
The discussion revolves around the concept of constraint forces in mechanics, particularly in the context of the principle of virtual work. Participants explore the definitions, implications, and applications of constraint forces, especially in relation to equilibrium conditions in rigid bodies and other systems.
  • One participant queries the definition of constraint forces and whether all internal forces qualify as such.
  • Another participant explains that constraint forces restrict particle movement, providing examples like the normal force in contact situations and asserting that internal forces in rigid bodies are constraint forces.
  • There is a discussion about the condition for equilibrium, where one participant notes that the sum of applied forces equating to zero does not necessarily imply that the body is in equilibrium.
  • Some participants suggest that for systems with ideal constraint forces, the condition of zero work done by constraint forces leads to equilibrium under certain assumptions.
  • There is a repeated inquiry about the applicability of the notion of constraint forces beyond rigid bodies.
Participants express differing views on the implications of the principle of virtual work and the conditions for equilibrium. While some agree on the definitions and examples of constraint forces, there remains uncertainty regarding their broader applicability and the relationship between zero virtual work and equilibrium.
Participants highlight that the assumptions regarding ideal constraint forces and their work being zero are critical to the arguments presented. There is also mention of the need for clarity on the conditions under which these principles apply.
pardesi
in the "derivation" of 'principle of vitual work' Goldstein started with this
he wrote the force F acting on each particle as the sum of [tex]F_{a}[/tex] (Force applied) and [tex]F_{i}[/tex](Constraint force)
ok i have some three queries
1)What are constraint forces?
2)Are all internal forces constraint forces
3)He said the cond. of equilibriia of a system is equivalent to
[tex]\sum \vec{F_{a,i}} .d \vec{r_{i}} =0[/tex]
that is the virtual work is [tex]0[/tex] i don't get how that happens(because virtual work being 0 doesn't imply force on each particle of the system is [tex]0[/tex] or is it just by definition?
The constraint forces are the forces which restrict the particle to move in some way. One example is the normal force, when two surfaces touch. For a rigid body, if you look at the forces on a single constituent particle, then the internal forces are indeed constraint forces.
What Goldstein says is that, if [itex]F_i[/itex] is the total force on a particle, and for a virtual displacement [itex]\delta r_i[/itex], the product [itex]F_i . \delta r_i[/itex] is 0 since each particle is at equilibrium, and so the sum over all particles [itex]\sum_i \bf{F}_i . \delta \bf{r}_i=0[/itex].
If you write [itex]F_i[/itex] as the sum of an applied force [itex]F_i^a[/itex] and a constraint force [itex]f_i[/itex], and only consider systems where [itex]\sum_i f_i.\delta r_i[/itex] is assumed to be 0, the condition for equilibrium is now, [itex]\sum F_i^a . \delta r_i=0[/itex]
This assumption holds for many cases. For example, in rigid bodies where the internal forces are constraint forces, then because of Newton's third law, the work due to the constraint forces is 0. Similarly, when the normal force from a surface is the constraint force, the work done is again 0, because the constraint force will always be perpendicular to the virtual displacement.
i was clear about the rigid body part but does the notion of constarint force hold good anywhere else?
also about the principle of virtual work
it's clear that if the body is in equilibrium with constarint foprces doing no work then we have
[tex]\sum \vec{F_{i,a}}.\vec{dr_{i}}=0[/tex] but [tex]\sum \vec{F_{i,a}}.\vec{dr_{i}}=0[/tex] does not imply that the body has to be at equilibrium
For systems with ideal constraint forces, where [itex]\sum f_i.\delta r_i[/itex] is assumed to be 0, then if [itex]\sum_i \bf{F}_i^a . \delta \bf{r}_i=0[/itex] for any arbitrary displacement [itex]\delta r_i[/itex], it implies the system is in equilibrium. Just reverse the sequence of arguments.
oh ok i think i got the point ...the thing is for any disp
  • · Replies 17 ·
  • · Replies 0 ·
