Thread Closed
Specific Heat / Debye Temperature
Share Thread
May4-08, 04:48 PM   #1
At what temperature T does the specific heat of the free electrons become larger than the specific heat of the lattice? Express T in terms of the Debye temperature and the electron concentration. Calculate T for copper (Debye = 343 K).
2. Relevant equations
Unfortunately, I have a ton of equations but have no clue which one to use. There are different equations for low and high temperatures, so I'm not sure where to start with this problem.
3. The attempt at a solution
Once I have the first part, I can solve for T for copper. I think I'm supposed to use some equations involving heat capacity and temperature, but no clue which one??? Any hints may help! My book (Kittel's intro to solid state) is not helping...
Thanks!
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
May4-08, 09:13 PM   #2
Recognitions:
Homework Helper Homework Help
I'm assuming this is being done in the low temperature limit, where the total (constant volume) heat capacity of the metal goes as [itex] c_v = \alpha T + \gamma T^3[/itex], where the linear term corresponds to the electrons and the cubic term corresponds to the lattice (phonons). (In the high temperature limit both capacities, per particle, should be the same, making for a much less interesting problem!) I'm assuming you have what [itex]\alpha[/itex] and [itex]\gamma[/itex] are in your list of equations - I can't remember what they are, but the debye temperature is buried in [itex]\gamma[/itex], and presumably the electron concentration is buried in [itex]\alpha[/itex].
Anyways, from there it's a simple matter: determine when [itex]\alpha T/(\gamma T^3) = \alpha/(\gamma T^2) > 1[/itex].
Thread Closed
Similar discussions for: Specific Heat / Debye Temperature
Thread Forum Replies
[SOLVED] Quantity of Heat/Specific Heat Water+Iron Introductory Physics Homework 3
Specific Heat and Phase Change/Latent Heat Problems PLEASE HELP Introductory Physics Homework 5
Heat Capacity / Debye Temperature Advanced Physics Homework 0
specific heat and temperature Introductory Physics Homework 5
Debye Heat Capacity General Physics 1
