Register to reply
Shear Stress of a particular length rod
by pukey123
Tags: length, shear, stress
Share this thread:
pukey123
#1
May8-08, 03:34 PM
P: 4
Just a quick question:
Wikipedia tells me that due the shearing stress, the yeild strength of Stainless Steel is 520Mpa
But how can i find out the Yeild strength of a 100mm long rod with diameter 10mm.
Is the info for wikipedia based on a 1mx1mx1m cube? or some sort of SI unit.
Cheers
Phys.Org News Partner Physics news on Phys.org
Symphony of nanoplasmonic and optical resonators produces laser-like light emission
Do we live in a 2-D hologram? New Fermilab experiment will test the nature of the universe
Duality principle is 'safe and sound': Researchers clear up apparent violation of wave-particle duality
mgb_phys
#2
May8-08, 04:23 PM
Sci Advisor
HW Helper
P: 8,953
The stress doesn't depend on the length of the rod - it only depend son the cross section area.
Mpa is mega pascal - is a unit of pressure, 1 pa is one Newton/m^2
So 1Mpa is around 100,000 Kg/m^2, or 145psi
pukey123
#3
May8-08, 04:32 PM
P: 4
i see, but the what cross section area are the stresses relating to? and does it also depend on the shape?
If i see the value of 520MPA in a book for s steel, how can i use that to aplly it to a rod with a given diameter?
Andy Resnick
#4
May9-08, 08:02 AM
Sci Advisor
P: 5,523
Calculating the deformation of a rod requires three things- the applied stress, the mechanical properties of the rod, and the geometry of the rod. All you have right now is (I'm guessing) the Young's modulus for a particular type of stainless steel and the geometry of the rod.
Try surfing through these, see if it helps:
http://www.clag.org.uk/beam-menu.html
http://www.mhhe.com/engcs/engmech/be...ctureppt.mhtml
http://www.grantadesign.com/resource...ns/elastic.htm
Note- thin beams have a simple approximate solution. Yours, with an aspect ratio of 10, may or may not be amenable to that approximation.
Register to reply
Related Discussions
Shear stress Engineering, Comp Sci, & Technology Homework 3
Shear stress Engineering, Comp Sci, & Technology Homework 9
Shear stress eqn Engineering, Comp Sci, & Technology Homework 5
Shear stress eqn Advanced Physics Homework 0
Compressional stress & shear stress Introductory Physics Homework 1
