Find the diameter of copper wire
The discussion revolves around finding the diameter of a copper wire that has the same resistance as an aluminum wire of equal length and a specified diameter. The resistivities of copper and aluminum at room temperature are provided, which are essential for the calculations involved.
  • Participants discuss the application of resistivity in relation to resistance, questioning the setup and the equations involved. There is a focus on comparing the resistances of both wires and the implications of their respective resistivities.
Multiple participants are engaged in exploring the calculations and equations related to resistivity. Some have provided guidance on the correct approach, while others are clarifying their understanding of the relationships between the variables involved. There is an ongoing examination of the calculations, with participants noting potential errors and rounding issues.
Participants are working under the constraints of homework rules, which may limit the extent of direct assistance provided. The discussion includes a focus on ensuring accuracy in calculations and understanding the implications of resistivity in the context of the problem.
looi76
[SOLVED] Find the diameter of copper wire
Find the diameter of copper wire which has the same resistance as an aluminum wire of equal length and diameter 1.2mm. The reactivities of copper and aluminum at room temperature are 1.7x10^-8Ωm and 2.6x10^-8Ωm respectively.
Can someone please explain to me the way of solving this question?
Thnx in advance
Thnx in advance
I'm sure you mean resistivity :wink:. Anyway, this is a simple application of resistivity, so what is the equation for resistivity?
[tex]R = \frac{Pl}{A}[/tex]
What to do next :smile:
Well you're looking for when the two resistances are the same, so...
The lengths are also the same :frown: I am confused!
You have two equations,
[tex]R = \frac{\rho_c \ell}{A_c}[/tex]
And
[tex]R = \frac{\rho_a \ell}{A_a}[/tex]
For the copper and aluminium wire respectively. Can you see what to do next?
And
[tex]\frac{P_c}{A_c} = \frac{P_a}{A_a}[/tex]
[tex]P_c = 1.7 \times 10^{-8}\Omega{m}[/tex]
[tex]P_a = 2.6 \times 10^{-8}\Omega{m}[/tex]
[tex]A_a = \pi{r}^2[/tex]
[tex]A_a = \pi \times \left(\frac{1.2 \times 10^{-3}}{2}\right)^2[/tex]
[tex]A_a = 1.1 \times 10^{-6} m^2[/tex]
[tex]\frac{1.7 \times 10^{-8}}{\pi{r}^2} = \frac{2.6 \times 10^{-8}}{1.1 \times 10^{-6}}[/tex]
[tex]r = \sqrt{\frac{1.7 \times 10^{-8} \times 2.6 \times 10^{-8}}{2.6 \times 10^{-8}\pi}}[/tex]
[tex]r = 7.36 \times 10^{-5}[/tex]
Is my answer correct?
Nice work! Thanks for LaTeX'ing it up for me :approve:
You're good up until this point. Your next line is wrong,
A further word of caution: be careful with rounding errors, try not to round too early in your calculation, either leave all your calculations to the end, or store the intermediate answers in your calculator.
Welcome Hootenanny! and thanks for the help
[tex]r = \sqrt{\frac{1.7 \times 10^{-8} \times 1.1 \times 10^{-6}}{2.6 \times 10^{-8}\pi}}[/tex]
[tex]r = 4.78 \times 10^{-4}m[/tex]
Is this right?
Is this right?
Your method is correct, but your final answer is of by ~7x10-6 due to rounding errors.
[tex]{\color{red}A_a = 1.1 \times 10^{-6} m^2}[/tex]
By rounding errors I think you meant the area of Aluminum [tex]P_a[/tex] right?
[tex]A_a = 1.1309734 \times 10^{-6} m^2[/tex]
[tex]r = \sqrt{\frac{1.7 \times 10^{-8} \times 1.1309734 \times 10^{-6}}{2.6 \times 10^{-8}\pi}}[/tex]
[tex]r = 4.8 \times 10^{-6}[/tex]
Is this right?:rolleyes:
I did indeed.
Now you're two orders of magnitude and a rounding error off. I have 4.85...x10-4m.
Thanks Hootenanny! I got the final answer correct...
A pleasure :smile:
23K
29K
  • · Replies 30 ·
